Old 05-05-2006, 08:00 AM   #16 (permalink)
SRTforums Veteran^2
crosbysrt's Avatar
Member Number: 3047
Quote: Originally Posted by panama_king
Quote: Originally Posted by finch2582
last night my check engine light came on. i went to autozone and they checked it. this was the code that they found P2096 or P2098 Post Catalyst Fuel Trim System Low Limit. can anyone tell me what this means. the people at auto zone couldn't find it in there books.
can someone chime in on this also, because i got the same thing and cant figure out whats causing it? what do i need or to remove??
Sup bro, I think it means you are running lean.
crosbysrt is offline   Reply With Quote
Old 05-05-2006, 11:40 AM   #17 (permalink)
panama_king's Avatar
Member Number: 19377
Trader Rating: (26)
i just finished putting in the 75 PSI FPR from PTPerformance so im waiting to see what codes come up now............im clamped at 4.3 volts right now as well...........
-Iron Monkey
20G + Portfueler=
panama_king is offline   Reply With Quote
Old 05-05-2006, 11:47 AM   #18 (permalink)
SRTforums Veteran^2
crosbysrt's Avatar
Member Number: 3047
-Iron Monkey
You better get your a/f asap.
Old 05-05-2006, 01:11 PM   #19 (permalink)
srt4fun80's Avatar
Member Number: 34189
Trader Rating: (102)
so you are just clamped at a voltage and don't know what your a/f is??? this is not good
srt4fun80 is offline   Reply With Quote
Old 05-05-2006, 05:22 PM   #20 (permalink)
Trader Rating: (26)
im dynoing tomorrow to see where its at and then mess around with the SAFC II
-Iron MOnkey
Old 05-17-2006, 08:27 AM   #21 (permalink)
srt4Rob's Avatar
Member Number: 34154
Trader Rating: (39)
P0133 ... anyone out there ???
wat the hell does "P0133 HO2S Slow Response Bank 1 Sensor 1 " mean ??
any help would =be awsome .. how can i solve this prob???
60 trim n built 2.5 blah blah blah
srt4Rob is offline   Reply With Quote
Old 05-17-2006, 10:35 AM   #22 (permalink)
srt4Rob's Avatar
Trader Rating: (39)
wat does that mean ??? anybody
Old 06-05-2006, 07:24 PM   #23 (permalink)
Trader Rating: (26)
still getting the p2096 code but my a/f is at 11.2 to redline.
any info????? thanks
Old 06-13-2006, 03:04 PM   #24 (permalink)
uberingram's Avatar
Member Number: 447
People, this thread is for a listing of trouble codes. You want help? Search then post in the correct forum for some help.
Chris ~ Janky '03
uberingram is offline   Reply With Quote
Old 07-15-2006, 12:05 PM   #25 (permalink)
Member Number: 5742
Default Some wierd codes
I just finished installing my Profec B Spec II and kept getting p0073 (not listed here). My OBDII scanner knows it as ABIENT AIR TEMP OVERVOLT. Checked and I neglected to connect the sensor wire on the air box. After fixing that, I got the following codes shown up as stored, all of which are not listed here:
C0458, P2973, U3700, C0470, B1F00. Any ideas on these? I have cleared them and they did not reappear yet. Any help would be appreciated.
Jeff Clevenger
'04 Blue, STS, Hotchkis Sway Bars
MP Rear Tension Stuts
H&R Coil Overs - set 14" hub to fender
Enkie RPF-1 17x7.5/Goodyear F1 GS D3 225/45/17
S0/AGP WGA Profec B Spec II 19/15/PTP Map Clamp/PTP FPR Mod
STS w/ Rage shifter bushings
Power slot rotors/Hawk pads
PTP stage 3 clutch & Al flywheel
PTP PVC check valve
jeffclevenger is offline   Reply With Quote
Old 08-21-2006, 11:30 AM   #26 (permalink)
Member Number: 9642
i need to know what p 0513 is please pm me!!!!!
Tyko is offline   Reply With Quote
Old 11-08-2006, 01:36 AM   #27 (permalink)
JohnnySrt4's Avatar
Member Number: 44657
anyone know how to fix the p1188 code EOT Sensor Ckt. High Voltage ?
3 inch down pipe, Cold Air Intake with splash guard, AGP Waste Gate, Apexi Neo Fuel Controller, oil pressure gauge, Wide Band, Air Fuel gauge, Tip Mod, Falcon Azenus Tires, Cross Drilled Slotted Roters,Co2 Inner Cooler Sprayers, SQV BOV, ATP Hard Pipe, re-routed Vaccum lines, Jet Chip, Oil Catch Can, Homemade Block off plate out of Half Inch Steel...
JohnnySrt4 is offline   Reply With Quote
Old 11-12-2006, 07:09 PM   #28 (permalink)
Corey_BLKSRT_0030's Avatar
Member Number: 39415
Trader Rating: (12)
bump...
Corey_BLKSRT_0030 is offline   Reply With Quote
Old 11-23-2006, 07:15 PM   #29 (permalink)
Trader Rating: (26)
can anyone tell me why im getting p0108 please??
-chango
Old 12-20-2006, 08:21 AM   #30 (permalink)
vade46's Avatar
Member Number: 2813
After 67k miles I got my first CEL on, but I have tried every freakin sequence you could do with the key and I can't get the car to read anything........what do I do?
2003 SRT-4
1987 Mustang GT Convertible
2005 Kawasaki ZX-6R
Before you Judge a man, walk a mile in his shoes. After that.....Who cares, he's a mile away and you've got his shoes!!
vade46 is offline   Reply With Quote
Page generated in 0.28292 seconds with 11 queries
