Quote: Originally Posted by colombian srt4
i have p0038 code .only i can boost 5psi. i can't reset this code disconnecting the battery. what do i need to do?
P0038-O2 SENSOR 1/2 HEATER CIRCUIT HIGH
When Monitored: Battery voltage above 10.6 volts, ASD is powered up, and O2 heater is
off.
Set Condition: The O2 heater voltage is out of range high. One trip fault.
POSSIBLE CAUSES
O2 SENSOR HEATER OPERATION
O2 HEATER ELEMENT
O2 HEATER GROUND CIRCUIT OPEN
O2 SENSOR
O2 HEATER CONTROL SHORTED TO VOLTAGE
O2 HEATER CONTROL CIRCUIT OPEN
PCM
Is it under warrenty , if so take to dealer
