Old 07-15-2004, 02:38 AM   #1 (permalink)
OWN3D's Avatar
Member Number: 3362
Exclamation Trouble Code List
I dont remember who, but some one asked for some codes. well here a couple.
03-04 SX/SRT - HARD CODES
P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT
P0031-O2 SENSOR 1/1 HEATER CIRCUIT LOW
P0037-O2 SENSOR 1/2 HEATER CIRCUIT LOW
P0032-O2 SENSOR 1/1 HEATER CIRCUIT HIGH
P0038-O2 SENSOR 1/2 HEATER CIRCUIT HIGH
P0033-SURGE VALVE SOLENOID CIRCUIT
P0068-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION
P0071-AMBIENT TEMP SENSOR PERFORMANCE
P0072-AMBIENT TEMP SENSOR LOW
P0073-AMBIENT TEMP SENSOR HIGH
P0107-MAP SENSOR LOW
P0108-MAP SENSOR HIGH
P0111-INTAKE AIR TEMPERATURE SENSOR PERFORMANCE
P0112-INTAKE AIR TEMPERATURE SENSOR LOW
P0113-INTAKE AIR TEMPERATURE SENSOR HIGH
P0116-ENGINE COOLANT TEMPERATURE PERFORMANCE
P0117-ENGINE COOLANT TEMPERATURE SENSOR LOW
P0118-ENGINE COOLANT TEMPERATURE SENSOR HIGH
P0122-THROTTLE POSITION SENSOR #1 LOW
P0123-THROTTLE POSITION SENSOR #1 HIGH
P0125-INSUFFICIENT COOLANT TEMP FOR CLOSED-LOOP FUEL CONTROL
P0128-THERMOSTAT RATIONALITY
P0129-BAROMETRIC PRESSURE OUT-OF-RANGE
P0131-O2 SENSOR 1/1 VOLTAGE LOW
P0137-O2 SENSOR 1/2 VOLTAGE LOW
P0132-O2 SENSOR 1/1 VOLTAGE HIGH
P0138-O2 SENSOR 1/2 VOLTAGE HIGH
P0133-O2 SENSOR 1/1 SLOW RESPONSE
P0139-O2 SENSOR 1/2 SLOW RESPONSE
P0135-O2 SENSOR 1/1 HEATER PERFORMANCE
P0141-O2 SENSOR 1/2 HEATER PERFORMANCE
P0171-FUEL SYSTEM 1/1 LEAN
P0172-FUEL SYSTEM 1/1 RICH
P0201-FUEL INJECTOR #1
P0202-FUEL INJECTOR #2
P0203-FUEL INJECTOR #3
P0204-FUEL INJECTOR #4
P0234-OVERBOOST PERFORMANCE
P1106-BARO SOLENOID PERFORMANCE
P1188 TIP SENSOR PERFORMANCE
P0243-WASTEGATE SOLENOID CIRCUIT
P0300-MULTIPLE CYLINDER MISFIRE
P0301-CYLINDER #1 MISFIRE
P0302-CYLINDER #2 MISFIRE
P0303-CYLINDER #3 MISFIRE
P0304-CYLINDER #4 MISFIRE
P0315-NO CRANK SENSOR LEARNED
P0325-KNOCK SENSOR #1 CIRCUIT
P0335-CRANKSHAFT POSITION SENSOR CIRCUIT
P0339-CRANKSHAFT POSITION SENSOR INTERMITTENT
P0340-CAMSHAFT POSITION SENSOR CIRCUIT
P0344-CAMSHAFT POSITION SENSOR INTERMITTENT
P0420-CATALYTIC 1/1 EFFICIENCY
P0440-GENERAL EVAP SYSTEM FAILURE
P0441-EVAP PURGE SYSTEM PERFORMANCE
P0442-EVAP SYSTEM MEDIUM LEAK
P0443-EVAP PURGE SOLENOID CIRCUIT
P0452-NVLD PRESSURE SWITCH SENSE CIRCUIT LOW
P0453-NVLD PRESSURE SWITCH SENSE CIRCUIT HIGH
P0455-EVAP SYSTEM LARGE LEAK
P0456-EVAP SYSTEM SMALL LEAK
P0461-FUEL LEVEL SENSOR #1 PERFORMANCE
P0462-FUEL LEVEL SENSOR #1 LOW
P0463-FUEL LEVEL SENSOR #1 HIGH
P0480-COOLING FAN 1 CONTROL CIRCUIT
P0481-COOLING FAN 2 CONTROL CIRCUIT (NON-TURBO)
P0481-COOLING FAN 2 CONTROL CIRCUIT (TURBO)
P0498-NVLD CANISTER VENT VALVE SOLENOID CIRCUIT LOW
P0499-NVLD CANISTER VENT VALVE SOLENOID CIRCUIT HIGH
P0501-VEHICLE SPEED SENSOR #1 PERFORMANCE (AUTO TRANS)
P0501-VEHICLE SPEED SENSOR #1 PERFORMANCE (MANUAL TRANS)
P0506-IDLE SPEED LOW PERFORMANCE
P0507-IDLE SPEED HIGH PERFORMANCE
P0519-IDLE SPEED PERFORMANCE
P0508-IAC VALVE SENSE CIRCUIT LOW
P0509-IAC VALVE SENSE CIRCUIT HIGH
P0513-INVALID SKIM KEY
P0516-BATTERY TEMPERATURE SENSOR LOW
P0517-BATTERY TEMPERATURE SENSOR HIGH
P0522-OIL PRESSURE SENSOR LOW
P0551-POWER STEERING SWITCH PERFORMANCE
P0562-BATTERY VOLTAGE LOW
P0563-BATTERY VOLTAGE HIGH
P0572-BRAKE SWITCH #1 CIRCUIT LOW
P0573-BRAKE SWITCH #1 CIRCUIT HIGH
P0581-SPEED CONTROL SWITCH #1 HIGH
P0582-SPEED CONTROL VACUUM SOLENOID CIRCUIT
P0586-SPEED CONTROL VENT SOLENOID CIRCUIT
P0594-SPEED CONTROL SERVO POWER CIRCUIT
P0600-SERIAL COMMUNICATION LINK
P0601-INTERNAL MEMORY CHECKSUM INVALID
P0622-GENERATOR FIELD CONTROL CIRCUIT
P0627-FUEL PUMP RELAY CIRCUIT
P0630-VIN NOT PROGRAMMED IN PCM
P0632-ODOMETER NOT PROGRAMMED IN PCM
P0633-SKIM KEY NOT PROGRAMMED IN PCM
P0645-A/C CLUTCH RELAY CIRCUIT
P0660-MANIFOLD TUNE VALVE SOLENOID CIRCUIT
P0685-ASD RELAY CONTROL CIRCUIT
P0688-ASD RELAY SENSE CIRCUIT LOW
P0700-TRANSMISSION CONTROL SYSTEM
P0833-CLUTCH RELEASED SWITCH CIRCUIT
P0850-PARK/NEUTRAL SWITCH PERFORMANCE
P1105-TIP SENSOR SOLENOID CIRCUIT
P1115-GENERAL TEMP SENSOR PERFORMANCE
P1189-TIP SENSOR CIRCUIT LOW
P1190-TIP SENSOR CIRCUIT HIGH
P1593-SPEED CONTROL SWITCH STUCK
P1602-PCM NOT PROGRAMMED
P1603-PCM INTERNAL DUAL-PORT RAM COMMUNICATION
P1604-PCM INTERNAL DUAL-PORT RAM READ/WRITE INTEGRITY FAILURE
P1607-PCM INTERNAL SHUTDOWN TIMER RATIONALITY
P1696-EEPROM MEMORY WRITE DENIED/INVALID
P1697-EMR (SRI) MILEAGE NOT STORED
P1854-TIP BARO OUT OF RANGE
P2074-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION
- HIGH FLOW/VACUUM LEAK
P2096-DOWN STREAM FUEL SYSTEM 1/2 LEAN
P2097-DOWN STREAM FUEL SYSTEM 1/2 RICH
P2302-IGNITION COIL #1 SECONDARY CIRCUIT-INSUFFICIENT
IONIZATION
P2305-IGNITION COIL #2 SECONDARY CIRCUIT-INSUFFICIENT
IONIZATION
P2503-CHARGING SYSTEM VOLTAGE LOW
U0101-NO TRANSMISSION BUS MESSAGE
U0155-NO CLUSTER BUS MESSAGE
U0168-NO SKIM BUS MESSAGES
U110C-NO FUEL LEVEL BUS MESSAGE
Quote: Originally Posted by WRX4m3
I know i am wrong on many things, hell i even see the holes in my arguments when i post them , i have done it plenty of times before, and will do it many more.
CAUTION. He has a black belt in mouth.
OWN3D is offline   Reply With Quote
Old 07-15-2004, 02:40 AM   #2 (permalink)
RuFus's Avatar
Member Number: 10206
Trader Rating: (13)
was not me but thanks aways....
RuFus is offline   Reply With Quote
Old 07-15-2004, 02:45 AM   #3 (permalink)
OWN3D's Avatar
Member Number: 3362
no prob..
Old 07-15-2004, 11:32 PM   #4 (permalink)
4trs's Avatar
Member Number: 1380
Good deal. Thanks for this listing. If there are any more please add.
This is now a sticky. It will help out those who throw codes, and do not have a list available.
4trs is offline   Reply With Quote
Old 07-18-2004, 01:56 PM   #5 (permalink)
Satellite's Avatar
Member Number: 11813
Trader Rating: (57)
question is how do you pull up the codes....I tried the on, acc, on thing....nothing...
Satellite is offline   Reply With Quote
Old 07-18-2004, 01:58 PM   #6 (permalink)
alpine's Avatar
Member Number: 5844
turn the key on-off (5 times) w/o starting the car...and you will get the P code in the odometer screen.
alpine is offline   Reply With Quote
Old 07-18-2004, 02:03 PM   #7 (permalink)
Satellite's Avatar
Trader Rating: (57)
thanks...that was easy....P0123
Old 09-16-2004, 11:38 PM   #8 (permalink)
Member Number: 17713
Hey watz up guys Have on 03 Black Srt-4 . My car just started flashing me the checking engine light. Did the procedure where u turn on and off ur car got the code for P0441. I gutted my exhaust and dont know if i should take it in the Dealership. Do u guys think theyll find out about my exhaust? Do n e of u guys have this problem?
JDM070 is offline   Reply With Quote
Old 09-26-2004, 04:53 PM   #9 (permalink)
Member Number: 11650
so any idea whats goign on with this code my car just threw it also.... i want engine light off!!! p0441 that is
UAintCool is offline   Reply With Quote
Old 12-16-2004, 03:13 PM   #10 (permalink)
killervenom's Avatar
Member Number: 14572
3 times works.
Current Mods : Psi-Fi CAI, MSD 8.5 MM Wires, Mpx Heat Shield, DC Front & Rear Strut Bars, Mopar STS, Booger Bushings, JLM Motor Mount's, AGP Race FMIC, JBM Hard Pipes, Billet Check Valve, TL retrofit projectors, Mpx UDP, SRT Oil Press., Pyrometer, LFS Fuel Rail, AEM UEGO
***ALL FOR SALE*** PM ME OR EMAIL
killervenom is offline   Reply With Quote
Old 12-20-2004, 02:49 PM   #11 (permalink)
oksrt's Avatar
Member Number: 8144
i just got p1697, 0234 and 2074. I fixed the 2074 reset the computer and no ses light anymore.
is there a fix for the overboost code on stage 0 and whats with the 1697
oksrt is offline   Reply With Quote
Old 01-10-2005, 05:53 PM   #12 (permalink)
madsrt's Avatar
Member Number: 3890
Trader Rating: (18)
P0633-SKIM KEY NOT PROGRAMMED IN PCM what does this mean????
madsrt is offline   Reply With Quote
Old 01-10-2005, 08:49 PM   #13 (permalink)
madsrt's Avatar
Member Number: 3890
Trader Rating: (18)
anybody out there?????
Old 01-10-2005, 08:56 PM   #14 (permalink)
Mopar Event Specialist
Dale Seeley's Avatar
Member Number: 150
It doesn't need to be a sticky, it's in the FAQ noobs...
Street Ricers Unite! We've been persecuted too long.
Dale Seeley is offline   Reply With Quote
Old 01-18-2005, 09:36 AM   #15 (permalink)
4trs's Avatar
Member Number: 1380
Hey Noob
Look at the date this baby became a sticky...lol. Way before the new modified FAQ.
BTW we finally got real snow here this week in Rochester. Im looking at 10 inches of it...
FS: Red 2003 SRT-4 Low Miles/S2-N-more/Clean/$14k
Pm me.
Page generated in 0.22265 seconds with 13 queries
