Old 04-01-2008, 10:19 AM   #151 (permalink)
SRTron-4's Avatar
Member Number: 41543
i just go code 1188. Air/Fuel metering. I got an 05, any ideas on what this is and how to fix it.
SRTron-4 is offline   Reply With Quote
Old 04-02-2008, 09:52 PM   #152 (permalink)
05SRT-4PowerHouse's Avatar
Member Number: 59714
ok so im throwing the 0420 catalytic 1/1 efficiency code. And i only put on a needswings DP 2 weeks ago... wouldnt it throw it 2 weeks ago?? Do i have a problem? or is it just the aftermarket DP?
05SRT-4PowerHouse is offline   Reply With Quote
Old 04-02-2008, 10:30 PM   #153 (permalink)
Elected Moderator
05Flame red's Avatar
Member Number: 37340
Trader Rating: (10)
My car threw that code a few weeks after I got a new down pipe. I had the 02 sensor wires lengthened to fit past the cat. A quick reset of my computer got rid of the code for as long as I had the stock computer. About 2 months
05Flame red is offline   Reply With Quote
Old 04-04-2008, 07:12 PM   #154 (permalink)
YngNBrk*zItR0's Avatar
Member Number: 51885
Same thing here. Any one know how to fix that?
YngNBrk*zItR0 is offline   Reply With Quote
Old 04-05-2008, 10:12 PM   #155 (permalink)
Member Number: 38347
Ok so here the situation with my code/problem. Was listening to the cd player while painting then my cd player just went out, just shut off. everything works but the cd player. I try to start to car and makes a grinding noise so i stopped trying. I threw a 0108 map sensor voltage high code any help would be great.
BlaziN253 is offline   Reply With Quote
Old 04-14-2008, 07:08 PM   #156 (permalink)
cokey's Avatar
Member Number: 17219
U0155-NO CLUSTER BUS MESSAGE
U0168-NO SKIM BUS MESSAGES
U110C-NO FUEL LEVEL BUS MESSAGE
damn visteon radiator.. lol.. we put on the new rad.. hooked up a fan switch mod. installer put it to the ignition for power.. i had shut the car off with the switch on. throw some codes. cleared it.. going to work today i blew the #11 fuse (where its connected).. instumeant cluster shut down.. everything, speedo, tach, fuel, temp.. put in a 20amp fuse. everything works but got those codes.. gonna clear them tomorrow and see if they come back. what to do if they do?
mike, itzcokey@aol.com
FS drive side head light $50 + shipp (obo); stock ic $60+ shipp; silver wing perf cond 100$ obo; crash bar 50 + shipp; stck cold side
makeover http://www.srtforums.com/forums/showthread.php?t=345296
cokey is offline   Reply With Quote
Old 04-15-2008, 07:39 AM   #157 (permalink)
SRToc Member
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
Check both headlamp ground connects are attached to the body frame in front of the radatitor.
hemidakota is offline   Reply With Quote
Old 05-26-2008, 12:30 AM   #158 (permalink)
rayray7734's Avatar
Member Number: 56105
general evap system failure? what the hell is that? how do i fix?
rayray7734 is online now   Reply With Quote
Old 06-01-2008, 08:25 PM   #159 (permalink)
looking4asrt4's Avatar
Member Number: 60776
subscribed..
looking4asrt4 is online now   Reply With Quote
Old 08-11-2008, 03:45 PM   #160 (permalink)
lilbroSRT's Avatar
Member Number: 49077
Quote: Originally Posted by Bofus View Post
hey I have this one too.(sorry if this is really late)If im not misstaken its a code you get for having stage 2: or at least thats what it says in the install instructions:
I have Stage 3 and thats the code im throwing, idk if there are other codes because i just reset my pcm by pulling that one yellow fuse, but my car is cutting fuel or something man, like it used to be only at high boost, it starts to stutter then cut, now even at low rpn, and just starting from a stop, it cuts a little ugh my car needs Jesus...or Tom Cruise... PLUS Dodge said im throwing an over boost and my downstream o2 is out, but stage 3 eliminates the downstream o2 and the turbo is bigger duh. if i press the pretty little red button(high octane) it revs a little higher but then does the fuel cut...help? my bro did the fuel pump rewire thing for me(stuff from autozone), and we are about to put that one 255 pump in...maybe i just need to gap my plugs... help!
03 stage 3 w/ turbo toys and other mods
car purchased from glhs837
fquick
lilbroSRT is offline   Reply With Quote
Old 08-11-2008, 07:19 PM   #161 (permalink)
SRTStu09's Avatar
Member Number: 62944
Quote: Originally Posted by 4trs View Post
Good deal. Thanks for this listing. If there are any more please add.
This is now a sticky. It will help out those who throw codes, and do not have a list available.
P0457 - EVAP System - Loose Fuel Cap
one of those that makes you go D'oh!
SRTStu09 is offline   Reply With Quote
Old 08-12-2008, 03:34 PM   #162 (permalink)
jalexiou@hotmail.com's Avatar
Member Number: 19893
Question Codes
Quote: Originally Posted by madsrt View Post
P0633-SKIM KEY NOT PROGRAMMED IN PCM what does this mean????
I also got P0633, as well as P0123 ?? The TPS sensor I understand, but the SKIM KEY ??
-S2 car installed at dealer
Ask an Engineer!
jalexiou@hotmail.com is offline   Reply With Quote
Old 08-23-2008, 01:48 PM   #163 (permalink)
Member Number: 64474
Default 0420
I have a 0420 code that just popped up, wht does catalytic 1/1 effeciency mean?
lipton1 is offline   Reply With Quote
Old 08-25-2008, 08:11 AM   #164 (permalink)
Ok well im going to take a wild guess and say you dont have a Cat on right now and that you prolly replaced it with a Needswings or with another aftermarket... and your still on a stock pcm...
Well if this is true then i dont think its really much to worry about... i never did... If you plan on atleast staging to 1 then it wont ever show up again... I think it means that its sensing that your cata has a higher flow then before and the effecincy is being lost thru a "leak" in the exhuast...(again if you have a dump then hell yea thats a huge leak)... but nothing to really worry about...
Old 08-26-2008, 04:45 PM   #165 (permalink)
Default 0420
I actually have a stage 2 with a stage 2 pcm, I bought it like this, but I got got it tuned by a friend, and I just got a new coil and new wires.
