Old 11-12-2006, 05:05 PM   #1 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (15)
Default TPS problem!!
Ok a buddy of mine..His car has the high idle and the surging I told him to purchase the tps repair kit from S&P but we dont have a soldering iron ...So if he just decides to take it to dodge (it is out of warrenty BTW) how much should it cost to get repaired??
Any info is much needed thanks in advance
AGP 44LB kit...
360whp/370wtq on 20psi
382whp/416wtq on 22psi
Both on pump gas on a SAFC
Now Diablosport tuned
Old 11-12-2006, 05:17 PM   #2 (permalink)
4DRVIPER's Avatar
Member Number: 6612
Trader Rating: (118)
Uhm, why not just buy a soldering iron? Paying someone to do something for you cost MONEY, learning to do something yourself, PRICELESS! lol Ok, to answer your question, IF the dealership would do this, I suspect they would charge your buddy half hour to 1 hour of their going shop rate.... Do yourself a favor and run to Walmart or some place and get a tool, you will use it over and over again, beside, one day someone may PAY you to have you do the same to their car.
4DRVIPER is offline   Reply With Quote
Old 11-12-2006, 08:50 PM   #3 (permalink)
Kason23's Avatar
Trader Rating: (15)
Well how hard is soldering??? Sry i have never done that..And any idea on how much they run?? I might get one ...Thanks!
Old 11-12-2006, 10:57 PM   #4 (permalink)
4DRVIPER's Avatar
Member Number: 6612
Soldering is easy...Strip the necessary wire(s), twist together, hold the soldering iron under, but directly touching the wires to heat them up, and then apply the soldering material and watch it melt and fuse the wires together...Easy! I am frugal, sooooo, I picked one up at Walmart for like 5.00. Glad to hear that you are contemplating learning this.... Hey its just another credit in your favor. Learn to do what you can so that you are able to keep more money in your pocket for modding
Old 11-13-2006, 07:02 AM   #5 (permalink)
Kason23's Avatar
Trader Rating: (15)
Thanks im going to pick on up today and give it a shot
Old 11-14-2006, 12:48 PM   #6 (permalink)
ENapa's Avatar
Member Number: 4408
Actually that is not the correct way to do it. You need to put solder on each end of the wires you are soldering together. Then you touch the two wires together and heat the solder that is on both ends up with the soldering iron. At least from everything I have read that is how it is supposed to be done.
RED - 2003 - SOLD -65k miles, for $12k
BLACK - 2004 - Welfare sways, MSD wires, NGKs, 17X7 ICW Racing glossy black, Mopar Exhaust, clear corners, clear 3rd brake light, Mopar BOV, blue LED dash lights, TWM sts,Booger bushings, Mopar S1 springs, SS brake lines, Tokico Illuminas, Kaminari CF hood, Projector headlights, SOLD
ENapa is offline   Reply With Quote
Old 11-14-2006, 04:54 PM   #7 (permalink)
stxsrt's Avatar
Member Number: 37057
Trader Rating: (28)
Default practice
Before you start soldering TPS wiring and stuff. Practice on some spare speaker wire or something just to make sure you can solder the TPS .my 2cents
stxsrt is online now   Reply With Quote
Old 11-14-2006, 04:58 PM   #8 (permalink)
flybye4's Avatar
Member Number: 28094
Trader Rating: (103)
you are correct...that is the way i was always told to do it. and i always thought this worked best
04' Yellow Jacket M6 GTO
99' Dark Bronzemist Metallic 2dr GTP
04' Metallic Silver SRT-4......SOLD
flybye4 is offline   Reply With Quote
Old 11-14-2006, 05:03 PM   #9 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (25)
So you just "tin" the tips of the wire then just join them together by the "tins"? Doesnt seem like there is much surface area to hold....
Old 11-14-2006, 05:09 PM   #10 (permalink)
04PAcruz'n's Avatar
Member Number: 8512
I did the repair myself because the stealership kept saying "can't duplicate problem". I crimped them together (using those little metal things for stereo wires) and didn't solder them. it did the trick and hasn't caused me a problem yet (knocking on wood). its been that way for about 35k miles.
Mods:
S2 w/o, JMB Ported IM+PTP 55mm TB, PTP charge pipe, Mopar TB Exhaust (cat-back+cat-delete), Mopar CAI, Spearco DF-IC, Samco IC hoses.
Mopar Stage 1 suspension (springs+sways), rear tension struts, Mopar front STB, Pwerks rear STB, mm inserts (street)
Mopar STS, Mopar BOV,4306 NGKs, JMB catchcan, Pwerks grounding kit, PTP check valve
04PAcruz'n is offline   Reply With Quote
Old 11-14-2006, 08:16 PM   #11 (permalink)
Kason23's Avatar
Trader Rating: (15)
Really.. sounds a little risky but hey if it works im ordering the repair kit tomorrow should i get it from S&P or should i stick to getting a mopar one is there really a difference??
» Sponsor Links
»Garage Storage and Cabinets
Page generated in 0.25712 seconds with 13 queries
