Old 09-04-2006, 01:28 AM   #1 (permalink)
Member Number: 30917
Default throwing 2 codes please HELP!
Hey guys just tonight i decided to check it for the hell of it and i ended up throwing a U110 and a U155 I dont know how i threw them though. the only thing i can think of is .... i diconected the stock boost gauge put a new one in and also changed the dash lights to led?? could that do it?
PLEASE HELP
white2005srt is offline   Reply With Quote
Old 09-04-2006, 01:55 PM   #2 (permalink)
Member Number: 28464
I dont remember who, but some one asked for some codes. well here a couple.
03-04 SX/SRT - HARD CODES
P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT
P0031-O2 SENSOR 1/1 HEATER CIRCUIT LOW
P0037-O2 SENSOR 1/2 HEATER CIRCUIT LOW
P0032-O2 SENSOR 1/1 HEATER CIRCUIT HIGH
P0038-O2 SENSOR 1/2 HEATER CIRCUIT HIGH
P0033-SURGE VALVE SOLENOID CIRCUIT
P0068-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION
P0071-AMBIENT TEMP SENSOR PERFORMANCE
P0072-AMBIENT TEMP SENSOR LOW
P0073-AMBIENT TEMP SENSOR HIGH
P0107-MAP SENSOR LOW
P0108-MAP SENSOR HIGH
P0111-INTAKE AIR TEMPERATURE SENSOR PERFORMANCE
P0112-INTAKE AIR TEMPERATURE SENSOR LOW
P0113-INTAKE AIR TEMPERATURE SENSOR HIGH
P0116-ENGINE COOLANT TEMPERATURE PERFORMANCE
P0117-ENGINE COOLANT TEMPERATURE SENSOR LOW
P0118-ENGINE COOLANT TEMPERATURE SENSOR HIGH
P0122-THROTTLE POSITION SENSOR #1 LOW
P0123-THROTTLE POSITION SENSOR #1 HIGH
P0125-INSUFFICIENT COOLANT TEMP FOR CLOSED-LOOP FUEL CONTROL
P0128-THERMOSTAT RATIONALITY
P0129-BAROMETRIC PRESSURE OUT-OF-RANGE
P0131-O2 SENSOR 1/1 VOLTAGE LOW
P0137-O2 SENSOR 1/2 VOLTAGE LOW
P0132-O2 SENSOR 1/1 VOLTAGE HIGH
P0138-O2 SENSOR 1/2 VOLTAGE HIGH
P0133-O2 SENSOR 1/1 SLOW RESPONSE
P0139-O2 SENSOR 1/2 SLOW RESPONSE
P0135-O2 SENSOR 1/1 HEATER PERFORMANCE
P0141-O2 SENSOR 1/2 HEATER PERFORMANCE
P0171-FUEL SYSTEM 1/1 LEAN
P0172-FUEL SYSTEM 1/1 RICH
P0201-FUEL INJECTOR #1
P0202-FUEL INJECTOR #2
P0203-FUEL INJECTOR #3
P0204-FUEL INJECTOR #4
P0234-OVERBOOST PERFORMANCE
P1106-BARO SOLENOID PERFORMANCE
P1188 TIP SENSOR PERFORMANCE
P0243-WASTEGATE SOLENOID CIRCUIT
P0300-MULTIPLE CYLINDER MISFIRE
P0301-CYLINDER #1 MISFIRE
P0302-CYLINDER #2 MISFIRE
P0303-CYLINDER #3 MISFIRE
P0304-CYLINDER #4 MISFIRE
P0315-NO CRANK SENSOR LEARNED
P0325-KNOCK SENSOR #1 CIRCUIT
P0335-CRANKSHAFT POSITION SENSOR CIRCUIT
P0339-CRANKSHAFT POSITION SENSOR INTERMITTENT
P0340-CAMSHAFT POSITION SENSOR CIRCUIT
P0344-CAMSHAFT POSITION SENSOR INTERMITTENT
P0420-CATALYTIC 1/1 EFFICIENCY
P0440-GENERAL EVAP SYSTEM FAILURE
P0441-EVAP PURGE SYSTEM PERFORMANCE
P0442-EVAP SYSTEM MEDIUM LEAK
P0443-EVAP PURGE SOLENOID CIRCUIT
P0452-NVLD PRESSURE SWITCH SENSE CIRCUIT LOW
P0453-NVLD PRESSURE SWITCH SENSE CIRCUIT HIGH
P0455-EVAP SYSTEM LARGE LEAK
P0456-EVAP SYSTEM SMALL LEAK
P0461-FUEL LEVEL SENSOR #1 PERFORMANCE
P0462-FUEL LEVEL SENSOR #1 LOW
P0463-FUEL LEVEL SENSOR #1 HIGH
P0480-COOLING FAN 1 CONTROL CIRCUIT
P0481-COOLING FAN 2 CONTROL CIRCUIT (NON-TURBO)
P0481-COOLING FAN 2 CONTROL CIRCUIT (TURBO)
P0498-NVLD CANISTER VENT VALVE SOLENOID CIRCUIT LOW
P0499-NVLD CANISTER VENT VALVE SOLENOID CIRCUIT HIGH
P0501-VEHICLE SPEED SENSOR #1 PERFORMANCE (AUTO TRANS)
P0501-VEHICLE SPEED SENSOR #1 PERFORMANCE (MANUAL TRANS)
P0506-IDLE SPEED LOW PERFORMANCE
P0507-IDLE SPEED HIGH PERFORMANCE
P0519-IDLE SPEED PERFORMANCE
P0508-IAC VALVE SENSE CIRCUIT LOW
P0509-IAC VALVE SENSE CIRCUIT HIGH
P0513-INVALID SKIM KEY
P0516-BATTERY TEMPERATURE SENSOR LOW
P0517-BATTERY TEMPERATURE SENSOR HIGH
P0522-OIL PRESSURE SENSOR LOW
P0551-POWER STEERING SWITCH PERFORMANCE
P0562-BATTERY VOLTAGE LOW
P0563-BATTERY VOLTAGE HIGH
P0572-BRAKE SWITCH #1 CIRCUIT LOW
P0573-BRAKE SWITCH #1 CIRCUIT HIGH
P0581-SPEED CONTROL SWITCH #1 HIGH
P0582-SPEED CONTROL VACUUM SOLENOID CIRCUIT
P0586-SPEED CONTROL VENT SOLENOID CIRCUIT
P0594-SPEED CONTROL SERVO POWER CIRCUIT
P0600-SERIAL COMMUNICATION LINK
P0601-INTERNAL MEMORY CHECKSUM INVALID
P0622-GENERATOR FIELD CONTROL CIRCUIT
P0627-FUEL PUMP RELAY CIRCUIT
P0630-VIN NOT PROGRAMMED IN PCM
P0632-ODOMETER NOT PROGRAMMED IN PCM
P0633-SKIM KEY NOT PROGRAMMED IN PCM
P0645-A/C CLUTCH RELAY CIRCUIT
P0660-MANIFOLD TUNE VALVE SOLENOID CIRCUIT
P0685-ASD RELAY CONTROL CIRCUIT
P0688-ASD RELAY SENSE CIRCUIT LOW
P0700-TRANSMISSION CONTROL SYSTEM
P0833-CLUTCH RELEASED SWITCH CIRCUIT
P0850-PARK/NEUTRAL SWITCH PERFORMANCE
P1105-TIP SENSOR SOLENOID CIRCUIT
P1115-GENERAL TEMP SENSOR PERFORMANCE
P1189-TIP SENSOR CIRCUIT LOW
P1190-TIP SENSOR CIRCUIT HIGH
P1593-SPEED CONTROL SWITCH STUCK
P1602-PCM NOT PROGRAMMED
P1603-PCM INTERNAL DUAL-PORT RAM COMMUNICATION
P1604-PCM INTERNAL DUAL-PORT RAM READ/WRITE INTEGRITY FAILURE
P1607-PCM INTERNAL SHUTDOWN TIMER RATIONALITY
P1696-EEPROM MEMORY WRITE DENIED/INVALID
P1697-EMR (SRI) MILEAGE NOT STORED
P1854-TIP BARO OUT OF RANGE
P2074-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION
- HIGH FLOW/VACUUM LEAK
P2096-DOWN STREAM FUEL SYSTEM 1/2 LEAN
P2097-DOWN STREAM FUEL SYSTEM 1/2 RICH
P2302-IGNITION COIL #1 SECONDARY CIRCUIT-INSUFFICIENT
IONIZATION
P2305-IGNITION COIL #2 SECONDARY CIRCUIT-INSUFFICIENT
IONIZATION
P2503-CHARGING SYSTEM VOLTAGE LOW
U0101-NO TRANSMISSION BUS MESSAGE
U0155-NO CLUSTER BUS MESSAGE
U0168-NO SKIM BUS MESSAGES
U110C-NO FUEL LEVEL BUS MESSAGE
je'ssrt-4 is offline   Reply With Quote
Old 09-04-2006, 01:59 PM   #3 (permalink)
I highlighted your codes in red. I bet it is from messing around with the dash cluster
Old 09-04-2006, 05:38 PM   #4 (permalink)
Thatnks so it is nothing i have to worry about then?
Old 12-20-2006, 11:31 PM   #5 (permalink)
Member Number: 33440
Default hey need help with this codes u0115 and u110c
car was running great but all my guages bounces on and off except for my fuel and boost gauge. and interior lights(abs,checkengine,antitheft,brake,low oil) goes on and off. two codes came u110c and u0115
need help..... how did u guys fix these code
going nuts with this codes
aj_zapflo27 is online now   Reply With Quote
Old 01-11-2007, 01:33 PM   #6 (permalink)
Member Number: 35539
Did you end up fixing yours. My car is having this problem now
ricardoa1 is offline   Reply With Quote
Old 01-28-2007, 03:45 PM   #7 (permalink)
Vooduguru's Avatar
Member Number: 944
Trader Rating: (13)
anyone??
The international WTF symbol
Vooduguru is offline   Reply With Quote
Old 01-28-2007, 05:50 PM   #8 (permalink)
Quote: Originally Posted by Vooduguru
anyone??
Make sure you have the connectors on the ecu nice and tight.
Check the fuse panel.
And last if you have a S2 code scrubbler make sure it is installed correctly.
I have not gotten the code for a few weeks and thats what I did.
Old 01-28-2007, 10:31 PM   #9 (permalink)
Member Number: 11680
Trader Rating: (21)
I am throwing the U0155 code now as well. Guage cluster is going nuts.
Quote: Originally Posted by thepowertowin
I was thinking of using some expanding foam to fill her in. Kind of like taxidermy for blow-up products.
srtfun is offline   Reply With Quote
Old 01-29-2007, 12:48 AM   #10 (permalink)
Vooduguru's Avatar
Member Number: 944
Trader Rating: (13)
Weird, mine threw the codes, gave the CEL, then before I could do anything, the CEL went away and so did the codes
Old 01-29-2007, 03:31 PM   #11 (permalink)
There is a data wire I forget the color runs from the ECU to the fuse box and OBD connector. then Goes to the cluster. This wire i belive causes that code. when the communication is lost between the ECU and the cluster.
Old 01-29-2007, 03:36 PM   #12 (permalink)
its VIOLET / YELLOW
Old 02-23-2007, 06:34 PM   #13 (permalink)
Impact23's Avatar
Member Number: 26385
I am throwing this code now also. I have 2 questions..... What was the dealers fix and was it covered under warranty. If it wasn't covered what did they charge you to fix it?
IMPACT
"Smoking a JDM near you"
~Mark~
Impact23 is offline   Reply With Quote
Old 02-23-2007, 08:46 PM   #14 (permalink)
Trader Rating: (21)
My car is still at the dealership. They arent sure what the problem is now. U0155 code is gone. Now they have P0513 and U0168. Both skim related codes.
» Sponsor Links
»Garage Storage and Cabinets
Page generated in 0.22916 seconds with 13 queries
