Quote: Originally Posted by
ItaLian SRT4
I have a problem similar to that. me and my boys cant figure out what it is. My car idles at 1000 rpms once im stopped. but when im drivin the car goes by itself once rpm drop to about 2000. then when im drivin and put the car in neutral its holds at 2 then i step on the brakes and the rpms drop then go up for a few seconds then go back down to 1000. i replaced the tps sensor and tps wires. still doing it.. any advice?
Pull the connector off of the IAC.
It will throw a code, but it can fix some of the bad idle/bad neutral RPM problems.
I actually drove around for months with the IAC disconnected.
If it does fix your RPM problems, replace the IAC and/or the wiring to the IAC.
(Since you've already replaced the TPS and TPS wiring.)
This is what my problem ended up being the second time I had issues with idle RPM, etc.
I replaced the TPS wiring and TPS sensor before getting around to the IAC as the culprit.
The first time I had idle issues ended up being a crack in my intake manifold gasket... which was accompanied by some lovely high pitched whistling at times.
