Old 11-13-2008, 09:48 PM   #1 (permalink)
jamie640's Avatar
Member Number: 68871
Default Stock Turbo Question
Hey i have an 04 srt-4, got it not too long ago, it has 20000miles, and it's completely stock except for a cold air intake. Anyways is it normal for the turbo to blow a little bit of oil in the boost lines? I noticed the bottom hose connected on the front left intercooler fitting was sweating, with a drop of oil hanging off the hose clamp, i took the hose off and its wet with oil in there. Ive never had to add oil or noticed it using oil or anything.
And if you guys would know, i have what seems like a slight engine missfire at idle on the engine. If you watch the engine it will shake a bit every 5 seconds or so, and when youre sitting at idle at a red light in the car i can feel a little bump sitting in the seat every now and then while idleing, its like the exaust system rumbles a bit. I had it in at the dodge dealership still on warranty, and they said bad plugs, i guess it isnt warranty to change the plugs and they wanted $154 to do it, so i said no and replaced them myself, and it didnt really make a difference. I checked the plug wires for resistance and theyre about 3.3K ohms, is that normal? Has anyone had this problem before, what could it be? Oh and yes i guess i should have asked them about the turbo blowing oil while it was in there but didnt notice it until after. Thanks alot guys!
jamie640 is offline   Reply With Quote
Old 11-13-2008, 09:52 PM   #2 (permalink)
Member Number: 37923
the oil in the cool side charge pipe in normal. all turbo engine cause oil in the intake, the fix is get an oil catch can. The rough running is normal too. From what i was told is that our cars have a performance cam and causes the engine to run rougher. What kind of plugs did you out in?
wooden is offline   Reply With Quote
Old 11-13-2008, 09:58 PM   #3 (permalink)
jamie640's Avatar
the engine miss and oil blowing is normal? is every srt4 like that??
Old 11-13-2008, 10:10 PM   #4 (permalink)
srtmatty's Avatar
Member Number: 65788
you need to get a catch can, for the plugs get ngk 4306's with some msd wires should run you bout $60 for everything
MOPAR MADNESS
srtmatty is offline   Reply With Quote
Old 11-14-2008, 08:24 AM   #5 (permalink)
uberingram's Avatar
Member Number: 447
For the most part. These cars blow a lot of oil through the PCV and tend to eat plugs and wires pretty quick. Do as suggested above.
Chris ~ Janky '03
uberingram is offline   Reply With Quote
Old 11-17-2008, 01:54 AM   #6 (permalink)
BigMac's Avatar
Member Number: 18060
To answer your other question, 3.3k ohms is within the acceptable range for plug wire resistance per the service manual. But I agree with the others, plugs and wires are the prime suspect, and look into a catch can.
2004... ..ARL ~ CGS ~ GWA
BigMac is offline   Reply With Quote
Page generated in 0.23476 seconds with 13 queries
