Old 06-22-2007, 08:50 AM   #1 (permalink)
andrewsboots's Avatar
Member Number: 45507
Trader Rating: (39)
Question Stock Manifold Studs *pics*
I'm installing a new t3 manifold on my car and there is 1 stud that scrapes the bottom of the manifold. basically I can't tighten down the manifold because the stud is too close to the manifold.
I want to know if it actually can be removed? and what would be the easiest way to remove it?
better yet, if you know a better way to intall it let me know, im planning to use a short bolt in place of the stock stud
andrewsboots is offline   Reply With Quote
Old 06-22-2007, 09:00 AM   #2 (permalink)
phubarr's Avatar
Member Number: 36947
Trader Rating: (57)
Who's exhaust manifold is that?
2005 Black Dodge SRT-4 ACR - SCT PRP (S2 base), ND Performance TCS, Mopar Stage 3 Coilovers, Falken RT-615's, AFE Stage 2 CAI, Ported 52mm TB, MaxxFab 3" DP (catless), Innovate LC-1 wideband, Aeroforce Scan Gauge, and a Hurst Shifter.
1989 Black Dodge Daytona Shelby Turbo II
1972 Plum Crazy/Black Plymouth Roadrunner
phubarr is offline   Reply With Quote
Old 06-22-2007, 09:01 AM   #3 (permalink)
Trader Rating: (39)
treadstone performance
Old 06-22-2007, 09:03 AM   #4 (permalink)
phubarr's Avatar
Trader Rating: (57)
I'm willing to bet you're supposed to remove that stud. You can use a tool called a stud puller (aka stud extractor, stud remover). You could also use a pair of vice grips if you don't mind ruining the stud's threads. Did the manifold come with installation instructions?
Old 06-22-2007, 09:07 AM   #5 (permalink)
Trader Rating: (39)
no intall intructions but im sure they assume you would figure out it has to be removed.
I'm afraid i might break the stud with vice grips
Old 06-22-2007, 09:12 AM   #6 (permalink)
phubarr's Avatar
Trader Rating: (57)
Well, it's hard to see exactly what's going on in the pic, but it's hard to see if there's enough clearance for any tool to get a bite on the head of anything, whether it's the head of a bolt or the nut for a stud. I'd call and ask them what sort of voodoo they use.
Old 06-22-2007, 09:16 AM   #7 (permalink)
phubarr's Avatar
Trader Rating: (57)
I've used vice grips to remove studs plenty of times. If you're uneasy about it, use a stud puller. It applies the same twisting force on the stud as a pair of vice grips would, but it keeps the threads in tact.
A bolt might work better there, but from the pic, it doesn't look like you have enough clearance for a box end wrench to get a grip on the bolt.
Old 06-22-2007, 09:23 AM   #8 (permalink)
Trader Rating: (39)
thanks for all ur help man,
i'll figure it out.
Old 06-22-2007, 09:29 AM   #9 (permalink)
distinctdev's Avatar
Member Number: 22976
Trader Rating: (32)
shorten the stud some, pull the manifold towards the firewall a little bit and put that nut on first
R.I.P. Steven Lorenz 04.04.06
MySlips.com
Bench Racing Stops Here.
distinctdev is offline   Reply With Quote
Old 06-22-2007, 09:39 AM   #10 (permalink)
Trader Rating: (39)
got it, thnx
Old 06-22-2007, 09:43 AM   #11 (permalink)
Trader Rating: (32)
i would find a shorter stud or cut the existing one before i ran no stud at all
