Old 06-16-2008, 08:08 PM   #1 (permalink)
Member Number: 37603
Trader Rating: (26)
Default stock, camming? (video)
okay lets see... ive noticed this for awhile but never checked it out...
1.usually when i cold start it doesnt start right away
2. when it does start the wideband has no reading
3.usually it lobes like if i had new cams but motor is stock
i really dont know how to read the wideband that well but i think its running rich? correct me if im wrong please
and does anyone know why it lobes like this? it usually chopps harder than it does in the vid... and also usually does it when i cold start then when it warms it goes away kinda but then does it when im idling
its like 3 mins long
Test.......
Quote: Originally Posted by Flame View Post
THIS is why this site fails!
Dumb F***ing users creating dumb f***king threads wasting my dumb F***ing time.
^^^ Admin-waste of time
SRT-4_ACR is offline   Reply With Quote
Old 06-16-2008, 08:25 PM   #2 (permalink)
CIVICEATER's Avatar
Member Number: 16703
Trader Rating: (12)
Your running very lean at idle.
2003 Solar Yellow SRT-4
FFP 47LB Stage 3
Coolingmist Trunkmount Kit with Varicool Controller
MPx 3" Exhaust
AGP Intercooler
AGP CAI
Diablosport Tuner
11.87 - 118.94mph
^^22PSI on HOM (getting kicked out) and no tune
CIVICEATER is offline   Reply With Quote
Old 06-16-2008, 08:57 PM   #3 (permalink)
Ghowie's Avatar
Member Number: 33090
Trader Rating: (55)
Without a doubt lean you should be between 14.5 and 15.1 the higher the # the leaner you are running. the wideband goes blank cause at like 18 or so it's as far as the wideband reads. You need to add fuel at idel and most likely throughout the whole map,but if you have a rising rate fuel pressure regulator add fuel with that by uping the fuel psi untill you get to the high 15's on the wideband then fine tune with the safc untill you get it in the target area of 14.5/15.1 using the safc to make BIG adjustments will only cause the pcm to freak wich is why the regulator should be used to make biger adjustments and the safc to fine tune it
The pcm is seeing it and adds fuel thats why it bounces back and forth and you get that hicup. Buy a scan gauge so you can get the fuel trims straight and the car running right and get it to a dyno to tune the rest of it in before you lose a motor. IN boost you want your afr's in the low 11's to high 11's Pm me your safc map settings,base fuel psi if you have a rrfpr,and you mod list and maybe I can help you a little
Originally Posted by dansrt4
For a shop thats so behind maybe you should catch up on orders before you catch up to me.
Ghowie is online now   Reply With Quote
Old 06-16-2008, 10:07 PM   #4 (permalink)
Trader Rating: (26)
well i dont have a Fuel controller Stage 1 comp is controlling it... i have the AVC-R next to my boost gauge... when i WOT in 3rd my wideband reads 11.8 and at redline its at 12.7
so all i would need it an AFC to set it proberly and a dyno tune? would it be safe to get some S2 or 650's injectors?
ooh and one more thing... also alot of times at idle i can smell exhaust fumes, popped the hood once and saw a little smoke coming from the manifold i think... could this be because im too lean?
and i lost the pop and gurgle from the exhaust
Old 06-18-2008, 05:26 PM   #5 (permalink)
Trader Rating: (26)
bizzump...
Old 06-18-2008, 06:08 PM   #6 (permalink)
KlugSRT-4's Avatar
Member Number: 50458
Trader Rating: (33)
It should not matter how big your injectors are at idle. Stock is plenty for idle. It wouldnt even matter if you were running HIGH hp engine, stock injectors should idle just fine. Higher rpms is where bigger injectors come into play.
I am going to guess you have a exhaust leak before the upper O2 that is throwing the computer off at idle. It is WAY to lean at idle.
LLk
KlugSRT-4 is offline   Reply With Quote
Old 06-19-2008, 01:00 PM   #7 (permalink)
Trader Rating: (26)
hm... thought about that but never looked into it...
is there any other way of checking instead of taking it off?
Old 06-19-2008, 01:21 PM   #8 (permalink)
DPETRIE's Avatar
Member Number: 34835
Trader Rating: (21)
Get back there and check all your exhaust manifold bolts. Do you have a 3" o2 housing? If you do check those bolts as well and report back.
"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man"
-Elbert Hubbard
DPETRIE is offline   Reply With Quote
Old 06-19-2008, 05:33 PM   #9 (permalink)
Trader Rating: (26)
yea i have a MPx 3'' o2... i was thinking it was cracked...
i'll have to check tomorrow morning... its pouring outside
Old 06-22-2008, 02:14 PM   #10 (permalink)
mistabones's Avatar
Member Number: 30097
Trader Rating: (18)
bump! i been having the same problem
05 StoneWhite SRT-4
To Many Mods To List...
mistabones is offline   Reply With Quote
Old 06-22-2008, 02:28 PM   #11 (permalink)
Member Number: 25892
Replace the oxygen sensor lately? Mine was doing that at idle, had to just touch the gas and raise the RPM's a little and it would go away. That was on the downstream one. Didn't get a code either.
Mods: AGP GT3076R DBB Turbo
madwax is offline   Reply With Quote
Old 06-22-2008, 02:46 PM   #12 (permalink)
Super Moderator
SRT of the Month
uncommon©'s Avatar
Member Number: 39843
Trader Rating: (183)
o2 sensor, fuel pressure & exhaust leak all come to mind ...
I would also pick up a scan gauge & monitor the STFT (short term fuel trims) at idle
Old 06-22-2008, 10:43 PM   #13 (permalink)
Trader Rating: (26)
Thanks for all the replys...
i have brand new o2 sensors...
i think its an Exhaust Leak for me, because i can smell exhaust funes through the A/C vents when im at a stop.....
Old 07-10-2008, 05:25 PM   #14 (permalink)
Commoncontext's Avatar
Member Number: 60072
You defiantly have an exhaust leak. mine was doing the same thing. When the person before me had the car they put the 3"o2 cat replacing peace on with just three bolts. The gasket was shot. But as soon as i fixed it its was fine. Until someone cut thru my pipe looking for a cat on my car hehe. I was just pissed cause it cost me 50 bucks to get it welded back together. Gotta love criminals.
Commoncontext is offline   Reply With Quote
Old 09-01-2008, 05:22 PM   #15 (permalink)
Trader Rating: (26)
bizzump
yea its an exhaust leak thats causing it thanks
