After taking my car out for some pulls, my second gear wouldn't engage. There was no unusual noises during the pulls, the shifter just felt weak going into second. I checked my shift cables they are still intact from the shifter to the transmission. After driving around I noticed my gears were engaging a little sloppy as if I was missing a bushing on the cables. I did a quick pull and then after my 5th gear wouldn't engage. It would put me in 3rd as if I hit a wall to shift into 5th. The car has a new clutch ,throwout bearing, pivot fork, pivot ball ,slave and master cylinders with about 15k.Resivour is full of fluid. I think its the shift selector but im not 100% shure. What do you guys think?
UPDATE*
I removed the top cover of the transmission and everything seemed like its in good condition. The shift selector looked to be in good condition. What I did notice was that on the 5th gear shift fork the silver piece looks like a piece chipped off? Im not shure if that's normal? ive seen pics online and they look similar. But other then that I drained the transmission fluid and didn't see any metal shavings come out. I also adjusted the crossover cable and nothing changed. Im just unshure where to go from here other then removing the gear set or dropping the transmission. I would appreciate your input.
*the attached pic is one I found online but it looks exactly like mine.refer to the silver piece to see the chipped piece im talking about
Use an image sharing site like google+, imageshack, etc.
Get the URL of your image and encapsulate it in "img" tags. Click on the sun and mountains in the top of reply box.
Code:
Or type them yourself
[img]your_image_link_here[/img]
Then you will have something like this:
But I would venture to say that you may have some gear engagement issues with that piece damaged. Either that or you are not getting full clutch disengagement due to a work fork, pivot ball, etc.
Related Threads
Dodge SRT Forum
9.5M posts
106.7K members
Since 2002
