Shaking under acceleration (not axle) - Dodge SRT Forum
post #1 of 41 (permalink) Old 11-10-2009, 12:30 AM Thread Starter
Gramaloke's Avatar
Quoted: 0 Post(s)
So I've started experiencing a shaking when accelerating, the higher the rpms with more violent the shaking. I've read the results from searching and I came to the conclusion that it was the passenger side axle. So i replaced the axle today and sure enough the problem persists.
now, while i was under there I noticed just how torn up my control arm bushings are. the passenger side is completely thrashed and not really even intact. could the bushing be the cause of this shaking while accelerating or is there something else I should consider?
Gramaloke is offline
post #2 of 41 (permalink) Old 11-11-2009, 03:40 PM
SRT4BanginTurboPVO's Avatar
Quoted: 2 Post(s)
sounds like ur bushings need replaced anyway i'd try that and see if it fixes ur problem
SRT4BanginTurboPVO is offline
post #3 of 41 (permalink) Old 11-11-2009, 04:29 PM Thread Starter
Gramaloke's Avatar
Quoted: 0 Post(s)
new bushings are en route. im hoping this fixes things. I just didn't imagine worn bushings would cause shaking intermittently like this. thought it was the axle for sure.
post #4 of 41 (permalink) Old 12-18-2009, 06:42 AM
Pt SRT4's Avatar
Quoted: 0 Post(s)
Bushing
Hey did the bushings help? i am having the same problem, new axles, new bushing, balljoints but as i accelerate i still have the shaking in my car. I bought all MOOG products and axles from Central Auto.
***MEGASQUIRTED***
2001 Chrysler PT Cruiser Limited Edition
With:
2004 Dodge Neon SRT 4 Engine/Tranny SWAP
Check out my website for pictures of the build.
http://ptcruisernetwork.ning.com/profile/theshadow
Pt SRT4 is offline
post #5 of 41 (permalink) Old 12-18-2009, 10:23 AM
Quoted: 0 Post(s)
Bushings can cause the vibration but did you check the condition of your tires? possible bent rims or rim. If you have any unsual tire wear you need to have the tire replaced and the alignment checked. Also the front tires might need to be balanced.
boostoutcast is offline
post #6 of 41 (permalink) Old 01-14-2010, 11:39 AM Thread Starter
Gramaloke's Avatar
Quoted: 0 Post(s)
i have not actually remedied this problem. I thought it had been fixed when i replaced the control arm bushings. I was wrong. Sometimes it shakes violently when accelerating and sometimes it's subtle. But its most definitely still a problem and now a whirring sound is coming from the front drivers side.
I'm guessing the stock clutch that has been in there for the 90,000 miles is starting to hurt. After all, this did start happening after the D44 install and the WOT pulls that come with a new turbo.
post #7 of 41 (permalink) Old 01-14-2010, 11:42 AM
2011 Calendar Car
CONROY's Avatar
Quoted: 0 Post(s)
check the hub/bearing, ball joint, tie rod end... i guarantee it is one of them.
CONROY is offline
post #8 of 41 (permalink) Old 01-14-2010, 12:22 PM Thread Starter
Gramaloke's Avatar
Quoted: 0 Post(s)
even if it's throttle specific?
it doesn't shake at all when in neutral and cruising. its ONLY in gear.
post #9 of 41 (permalink) Old 01-14-2010, 12:33 PM
SRT of the Month
bitts's Avatar
Quoted: 3 Post(s)
Does the car pull to one side under acceleration ?
NOW ON FB
bitts is offline
post #10 of 41 (permalink) Old 01-14-2010, 12:40 PM Thread Starter
Gramaloke's Avatar
Quoted: 0 Post(s)
I can't say that it pulls any harder than it usually did. However torque steer does pull it to the right if i hammer the gas with the turbo spooled.
I have an 03 with no LSD, for the record.
post #11 of 41 (permalink) Old 01-14-2010, 01:16 PM
juppes_Srt-4's Avatar
Quoted: 0 Post(s)
yeah i would check your tire rod i had the same problem someone hit and ran me at heb and bent my tire rod had bad shake under acceleration fixed it the problem went away.. good luck
gt3076r- the balls
fwd performance-the brains
new build complete.. numbers coming soon
juppes_Srt-4 is offline
post #12 of 41 (permalink) Old 01-14-2010, 01:23 PM Thread Starter
Gramaloke's Avatar
Quoted: 0 Post(s)
so clutch doesn't immediately come to mind when taking all the information into consideration?
I just want to cover all my bases. it does have 90+ thousand miles on it and this all started after some spirited driving with the D44.
post #13 of 41 (permalink) Old 01-14-2010, 02:27 PM
SRT of the Month
bitts's Avatar
Quoted: 3 Post(s)
Ball joints have they ever been replaced ?
NOW ON FB
bitts is offline
post #14 of 41 (permalink) Old 01-14-2010, 02:38 PM
2011 Calendar Car
NoisufnoC's Avatar
Quoted: 4 Post(s)
tire rod?
I remember the days of...
...most of you weren't born yet.
|| Mod List || RIP Mod List || (Re)Build Thread ||
|| Blog || Mr. November #3 ||
NoisufnoC is offline
post #15 of 41 (permalink) Old 01-14-2010, 02:40 PM Thread Starter
Gramaloke's Avatar
Quoted: 0 Post(s)
no, but passenger side is obliterated after closer inspection.
User Tag List
Linear Mode Linear Mode
