Serious questions serious problems heads gonna explode.... - Page 3 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-16-2013, 06:55 PM   #31 (permalink)
Member Number: 76837
Whats the 8th letter of the vin? If its a "C" its a swap.
Mod List: Built 2.4 with DCR Pro-Mod and a BW/AGP S-360RS along with every supporting mod. Currently 8psi a need bigger wheels/tires.
boostalot717 is online now   Reply With Quote
Old 01-16-2013, 07:02 PM   #32 (permalink)
Member Number: 91605
That's what it is can we get on to the big problems
Codes with the key turned 3 times
P0443
P0499
P0508
P0688
P0113
P0517
P0073
P0038
joeydub7 is offline   Reply With Quote
Old 01-16-2013, 07:05 PM   #33 (permalink)
roadrunner58's Avatar
Member Number: 77074
Check this link out:
For Sale: 2005 srt4 fully built white
roadrunner58 is offline   Reply With Quote
Old 01-16-2013, 07:07 PM   #34 (permalink)
Yea can't sell now its not a srt just found out haha
Old 01-16-2013, 07:07 PM   #35 (permalink)
Crazyced's Avatar
Member Number: 56385
P0443
P0499
P0508
P0688
P0113
P0517
P0073
P0038
P0443-EVAP PURGE SOLENOID CIRCUIT
P0499-NVLD CANISTER VENT VALVE SOLENOID CIRCUIT HIGH
P0508-IAC VALVE SENSE CIRCUIT LOW
P0688-ASD RELAY SENSE CIRCUIT LOW
P0113-INTAKE AIR TEMPERATURE SENSOR HIGH
P0517-BATTERY TEMPERATURE SENSOR HIGH
P0073-AMBIENT TEMP SENSOR HIGH
Start by getting all your sensor back where they should be and make sure they work.
Crazyced is online now   Reply With Quote
Old 01-16-2013, 07:12 PM   #36 (permalink)
I don't know where any those sensors are do you think previous owner removed em?
Old 01-16-2013, 07:12 PM   #37 (permalink)
Crazyced's Avatar
So you lost the DSP from a move? I though you didn't get one at all... For how long have you had the car?
Old 01-16-2013, 07:13 PM   #38 (permalink)
I don't know where any are haha and would any those cause low boost
Old 01-16-2013, 07:15 PM   #39 (permalink)
A year and its sat
Old 01-16-2013, 07:19 PM   #40 (permalink)
Crazyced's Avatar
Depends on how the WGA is hooked up. You didn't post a picture of it yet.
Old 01-16-2013, 07:20 PM   #41 (permalink)
STV3's Avatar
Member Number: 30874
Quote: Originally Posted by roadrunner58 View Post
Now it looks like he's trying to do to someone else what the guy he brought it from did to him....
AGP SOMETHING OR OTHER TURBO
TUNED BY NIGEL
373WHP
368WTQ
STV3 is online now   Reply With Quote
Old 01-16-2013, 07:25 PM   #42 (permalink)
benspilk09's Avatar
Member Number: 88421
Wait you don't have an intake for it? I figured you just had it off so you could see the engine more clearly. Best get some kind of filter on it ASAP.
The first two codes are probably from the evap system not being hooked up correctly, good luck with that. Could be lots of parts missing/broken or something as simple as the gas cap not sealing. You are definitely missing the evap purge solenoid, it is located on the drivers side fender of a stock car and has some wires and a white vacuum line running to it.
You're missing some sensors in your intake as well judging by the pictures, there should be a sensor in the intake itself and another on the cold side intercooler pipe that appear to be missing; should remedy the two temperature sensor codes.
The ASD relay is the one that's supposed to be bolted to the cam position sensor is it not?
IAC would be idle air control, check wiring to it, should be on the throttle body.
Please don't try and sell it in this condition, I absolutely despise people who do that crap. You might not have to spend that much money on it to make it right, most of it will be figuring out wtf it needs and what the previous owner did with everything.
benspilk09 is offline   Reply With Quote
Old 01-16-2013, 07:26 PM   #43 (permalink)
fivetoez's Avatar
Member Number: 9691
Bad Juju from that sale ..............
_____5TOEZ______ 1967 Cadillac Calais 429 2dr., 1967 Chevelle 4sp. Conv. ,1978 Dodge 318 "Factory Custom"van., 2004 Dodge Srt-4,Stage1.5(E-Blue) & a couple motorcycles.
Old 01-16-2013, 07:41 PM   #44 (permalink)
Crazyced's Avatar
Actually that's the TIP sensor.
Old 01-16-2013, 07:41 PM   #45 (permalink)
Hey guys no I'm not shady I went off what the previous owner told me... Now that I know I will get it all worked out myself. I appreciate all the help guys I decided to keep it that's why I just posted on here... Me and my wife are pretty upset as we got rid of a really nice truck for a 01 neon
