Watch "Srt4 bad start up" on YouTube
Srt4 bad start up: Srt4 bad start up - YouTube
So this is the problem I'm having after installing a new head gasket and head. . Not sure what the problem is. I primed the engine before starting to get oil in the turbo and what not. I did this with the the fuel pump fuse removed. Then plugged it in. Turned the key to the on position 3 times and I could hear the fuel pump turn on. Attempted to turn the car on and this happend... if I turn the car on and tap on the gas pedal the car will stay on,but once I let go the car dies. If I attempt to turn the car on it doesn't sputter or anything the r.p.m barley hit 1k and it dies. Not sure what it is. It took me about a week to finish the car. Only have a couple hrs a day to work on it. I was sure to set the timing correctly. The two notches we lined up perfectly. Don't think the timing bad because when I rev it it doesn't sound out of time. . I thinking the fuel pump is maybe taking a dump. It still the stock one and I have 144k on the car. And I'm the original owner. So I know what's been done and what hasnt.
Mods :2005 acr
Full stg 2
3in O2
3in dp with cat
exhaust mani with elbow mod.
Hks bov ,hot and cold ic pipe
Dsp
Mods :2005 acr
Full stg 2
3in O2
3in dp with cat
Dsp
