Power Steering Belt Help!! - Dodge SRT Forum
post #1 of 106 (permalink) Old 08-24-2011, 04:32 PM Thread Starter
Stage3 SRT4's Avatar
Quoted: 4 Post(s)
Ok yes i am new but i have done my research on this problem and tried it all. First the car:
2004 Dodge Neon SRT-4 Stage 3 W/Toys.
Only mods i can think of that would have an affect on anything do this is i have the Wishbone motor mounts(may not be relevant).
Sources i have read and tried:
Serpentine Belt pop off?
How-To: Replace Power Steering Pump
Ok so forth and so on.
The so called fix:
I was at the track(long story short) came off the line wheel hopped and broke and axel and broke the P/S reservoir. Ok went to a dodge dealership and paided $400 for a brand new pump.
One week later got on it in full boost and BAM the pulley shattered. Took it back off and returned it(gotta love warrenty work)and got a new one Installed it and then done some further inspection.
The belt is riding and actually pulling off the side of the pump. So i beat my crank pulley on checked my A/C brackets and all is good. Upon further inspection my P/S reservoir is actually hitting or not hitting but rubbing on my intake manifold. It hasnt busted or anything yet because i havent got on it any(dont want to risk messing another one up)thing like that.
Problem:
Belt is sitting about a 1/4 inch to towards the passenger side and trying to come off. It hasnt yet but before too long it will shread the belt. and the reservoir is touching my intake manifold.
Solution:
???? I have tried bending the brack and that didnt work out too well. I replaced the tensioner and still no help. Installed a new belt nothing.
What i need:
I need to know what to do to fix this problem. It really isnt a big deal but i dont want to take the risk of breaking the pulley or shreading a belt(again).
I would greatly appreciate any and all help. Thanks guys and gals.
Here are some pics to clear things up a little bit...
Oh yes and is is possible that i could get a spacer made? i have a friend who can make one he just needs the measurements. But i would still prefer to get it fixed the right way. And if anyone has had this problem and made a spacer send me the specs you used. Thanks again.
Stage3 SRT4 is offline
post #2 of 106 (permalink) Old 08-24-2011, 09:08 PM Thread Starter
Quoted: 4 Post(s)
bumpity....
post #3 of 106 (permalink) Old 08-24-2011, 09:16 PM
badboydneon's Avatar
Quoted: 0 Post(s)
maybe your motor mount bracket is slightly bent where the pump is mounted?
2004 Black SRT-4-
Mopar Stage 3 with the works
2003 Silver SRT-4-
BW s200sx-rs-56 .63ar
1997 Black 1G, 2.4 built and turboed-project
Any1 local in need of PCM flash...hit me up
badboydneon is offline
post #4 of 106 (permalink) Old 08-24-2011, 09:36 PM Thread Starter
Quoted: 4 Post(s)
yes i thought the same thing but the bracket is solid metal and i cant bend it back any i just tried and its too stought lol
post #5 of 106 (permalink) Old 08-24-2011, 09:52 PM
Quoted: 0 Post(s)
Lol, yea that is some thick metal. I mean, thats pretty much what it could be. Something defintly got tweaked when the axle broke.
2004 Black SRT-4-
2003 Silver SRT-4-
post #6 of 106 (permalink) Old 08-24-2011, 10:02 PM
kylejoseph426's Avatar
Quoted: 1 Post(s)
this would be my guess, thick but everythings possible
JMB Built
573HP
510TQ
91+meth/24psi
2011 Challenger SRT-8 392- Green With Envy
Kooks Long Tubes / JMB Exhaust
Comp Cammed / JMB Tuned
kylejoseph426 is offline
post #7 of 106 (permalink) Old 08-25-2011, 01:30 PM Thread Starter
Quoted: 4 Post(s)
how do ya'll suggest that i go about bending that thick thing back? lol maybe a torch and a pry bar?
post #8 of 106 (permalink) Old 08-25-2011, 01:32 PM Thread Starter
Quoted: 4 Post(s)
and you thing with the axel breaking thats what cause it? how?
post #9 of 106 (permalink) Old 08-25-2011, 05:26 PM
Quoted: 0 Post(s)
The only reason i think this is because u said it happened right when the axel broke. Another possibility...maybe 1 of the bolts for the bracket (that bolt to the block) broke, and now the bracket is tweaked the wrong way?
2004 Black SRT-4-
2003 Silver SRT-4-
post #10 of 106 (permalink) Old 08-25-2011, 05:53 PM
SRTFORUM Moderator
Advans's Avatar
Quoted: 71 Post(s)
I'd just shim the PS pump out. Easy to do.
Advans is offline
post #11 of 106 (permalink) Old 08-25-2011, 07:26 PM
Quoted: 0 Post(s)
^^ yea i guess thatd be the easier route
2004 Black SRT-4-
2003 Silver SRT-4-
post #12 of 106 (permalink) Old 08-25-2011, 09:25 PM Thread Starter
Quoted: 4 Post(s)
ok how do i do that? any write ups on it or info i could research?
And it will be a couple of days now i was playing around with a friend beside me and BOOM the pulley shattered so now i have to hope that warranty will replace it AGAIN
post #13 of 106 (permalink) Old 08-26-2011, 02:26 PM Thread Starter
Quoted: 4 Post(s)
Ok they are going to replace it but i have a question.....
The part where the motor mount connects to the big bracket on side of the motor(the one that holds the p/s pump), it only scews off on two places correct? One of my bolt holes are broke and not sure of the other one yet.
If you look at your on your motor where it screws into is a little spot made on the block and mine is broke so thats where the problem is, its broke and causing the motor mount to twist and have it in a bind and then throw the whole p/s pump off.
So i need to get it fixed. Anyone had the similiar problem happen or what?
And i believe the motor will have to be pulled and the block replaced?
Not sure i just need a little info on it
And also is there a belt that will just run the ac compressor? if so whats the part number so i can grab one it sucks without a a/c in alabama.
post #14 of 106 (permalink) Old 08-26-2011, 02:42 PM
SRTFORUM Moderator
Advans's Avatar
Quoted: 71 Post(s)
So a bolt broke off on the motor mount support bracket and is stuck in the block? Fuuuu! The support bracket is attached to the block by 3 bolts. I doubt you'd have to replace the block, I'm sure you could get the broken bolt out.
Not sure on the belt size to just run the A/C compressor.
Advans is offline
post #15 of 106 (permalink) Old 08-26-2011, 08:46 PM
Quoted: 0 Post(s)
lol i win.
u dont have to replace the block, u can get the bolt out but it will suck. u will need some good drill bits
2004 Black SRT-4-
2003 Silver SRT-4-
User Tag List
Linear Mode Linear Mode
