Plume of blue smoke on start up - Dodge SRT Forum
post #1 of 8 (permalink) Old 01-04-2012, 07:03 AM Thread Starter
Mrturbo24's Avatar
Quoted: 168 Post(s)
Hello world, so as we all know the weather in nj is reaching freezing temps and our cars are hating it! Anyway this is the situation
Its 27 degrees and my car has been sitting overnight. So i go to turn it on and everything seems ok until i notice a Cloud of blue smoke. It cleared in about litterally 3 seconds. It doesnt smoke @ ALL when driving nd it recently just started doing this (1st time)
The car has 105,780 (tial bov only mods)miles just did an oil change (m1 fs)
Ive done research and have came up with this
Bad valve seals?
Bad turbo?
Will a turbo timer help?
I need help guys Thanks
Mrturbo24 is offline
post #2 of 8 (permalink) Old 01-04-2012, 07:05 AM Thread Starter
Mrturbo24's Avatar
Quoted: 168 Post(s)
Ps installing my wideband on friday to c how the car is running
post #3 of 8 (permalink) Old 01-04-2012, 08:56 AM
Quoted: 0 Post(s)
The turbo is probably starting to go on you. If that's the case then it's a easy fix you can pick up a good used stock turbo for like $75-$100 bucks these days. If the turbo is alright then you might have other problems. I would start with a compression+leak down test then go from there. Good luck
PK's 04 SRT is offline
post #4 of 8 (permalink) Old 01-04-2012, 10:11 AM Thread Starter
Mrturbo24's Avatar
Quoted: 168 Post(s)
Where could i find a turbo for that price?(just for future refrence)
And just to make sure good compression numbers are 150ish?
Thanks for the help
post #5 of 8 (permalink) Old 01-04-2012, 12:36 PM Thread Starter
Mrturbo24's Avatar
Quoted: 168 Post(s)
Anyone ??
post #6 of 8 (permalink) Old 01-04-2012, 01:01 PM
a853rox's Avatar
Quoted: 9 Post(s)
Garage
Have you checked the for sale section? or posted up in the "want to buy" section?
Your Turbo, Cylinder head, and performance experts!
Bob Schreiber
Owner, Form and Function Performance LLC
612-385-0419
http://www.srtforums.com/forums/f313...rtwork-303415/
a853rox is offline
post #7 of 8 (permalink) Old 01-04-2012, 01:57 PM
Quoted: 147 Post(s)
4/2/12 edit -- it was a bad turbo
I have the same issue, recently rebuilt (kicking my self for not changing the valve stem seals).. & also in NJ
After the car was warm i had to add some oil (due to another issue) and had the same blue cloud..
My guess is the valve stem seals
<check turbo air inlet, if no oil and the shaft is tight -- guessing not the turbo>
405hp, 450tq
http://www.srtforums.com/forums/f451...w-123k-612933/
PCM=S0, DSP rescaled, 3bar map/tip
injectors= Siemens 80# (ebay $200)
built motor, 8.8:1 weisco, eagle-h, strap & windage
S3R DCR manifold ($500) w/evo8 turbo (ebay $150) - 20G/47# ebay ($200)
Evo 8 WGA
24x12x4 w/cast ends - CXRacing (ebay $200)
DataLogger DataQA, $25
Wideband UEGO (ebay $150)
vette rims 275/40/17
needswing v5
SouthBend S3
fixit is offline
post #8 of 8 (permalink) Old 01-04-2012, 05:48 PM Thread Starter
Mrturbo24's Avatar
Quoted: 168 Post(s)
i think i require a certain amount of posts to view it.
will do hopefully this weekend
User Tag List
Linear Mode Linear Mode
