Old 06-12-2008, 09:56 PM   #1 (permalink)
emmons_420's Avatar
Member Number: 61629
Default P2096 downstream O2 1/2 lean
i've a stock 05 srt-4 that i ran into a wall(front right at corner) @ nurburg. insurance fixed it in germany and i had it shipped back 2 years ago.
it's idling really rough after it starts to warm up sometimes, but when it'd bone cold and once it gets to operating temp it's fine.
somewhere between 160 and 190 degrees (in closed loop i think) it starts to loose vacume pressure (and rpm's sometimes) at idle. it seems to steadly loose vacuum (to around 10in)and then gains it all back at once making the car "buck" and accelerate quickly(if in gear) or will almost stall sometimes and have an erratic idle when left to warm up. once the needled on the vac guage starts dropping something raises my idle till the vacuum reads normal (arouond 17-19in. of vac) then it repeates the cycle till the engine is at operating temp(190-200 degrees). then it drives just fine. i threw a P2096 and the check engine light came on.
i took it to my local dealership and they refused to work on it, siting some king of bs about it having damage from running non mopar coolant.
so i took it to the next place and they found a bunch of my pcm connectors w/o the little locking clips. (thanks german insurance job!). their tech said it could be an evap can with solid fuel in it or a bad pcm. they told me they couldn't further diagnose the problem till that stuff was replaced anyway.
i'm pretty sure i have an exhaust leak somewhere between the engine and the downstream O2 sensor. how can i test for this? can anyone help me?
emmons_420 is offline   Reply With Quote
Old 06-13-2008, 04:11 PM   #2 (permalink)
slickwillie's Avatar
Member Number: 47326
hey man I just went though the same exact thing as far as the 2096 code they told me either bad gas or exhaust leak and the mechanic checked the o2 sensor and said it was a little weak and replaced it 2 weeks no problem. As far as the bucking and the vac my dealership replaced my throttle body, tps, and my intercooler I still have warranty so no problem but it did not fix it I told them to look at the tps harness so they replaced it and its all good so far its been 2 1/2 weeks now so I would try the tps harness I think they sell them at pt-performance pretty cheap
slickwillie is offline   Reply With Quote
Old 06-13-2008, 08:05 PM   #3 (permalink)
emmons_420's Avatar
word up
Old 06-19-2008, 09:51 AM   #4 (permalink)
Member Number: 45508
this is alittle off topic but i get the p2096 code too and it happend when i put my 3" Dp on with the fouler mod. i get the cat code w/o the fouler. other than repacing the o2 i have done everything i can think of.... but here is the off topic ?. is a universal o2 the same as the oem one???
05 Black SRT-4 Stock
OP's_srt is offline   Reply With Quote
Old 06-20-2008, 08:32 AM   #5 (permalink)
SRToc Member
arn4726's Avatar
Member Number: 22852
Trader Rating: (17)
YUP! i replaced my 02 sensor with the BOSCH one... works like a champ... all you hae to do is cut a lil and re connect with the new sensor...
arn4726 is offline   Reply With Quote
Page generated in 0.18394 seconds with 11 queries
