p0633 and p0243, headlight switch - Dodge SRT Forum
post #1 of 10 (permalink) Old 02-01-2007, 04:58 PM Thread Starter
New Member
Quoted: 0 Post(s)
just got my car back from the dodge body shop(was in a accident).. and I have a check engine light with codes: p0633 and p0243 but the car runs fine... could this be something not plugged in? maybe the body shop tech forgot to plug something in? I'm gonna take that stuff up with the body shop.. but wondered if anyone had any idea why I would get those codes but the car run fine....
the problem that bothers me the most is my headlight switch.. when I turn on the headlights, my windsheild wipers come on and wont stop till i turn the headlights off... if i just turn on the park lamps it's fine... but once i turn on the headlights the wipers come on.... the body shop replaced the left headlight(damaged in the accident) and the left foglight... could they have wired something wrong? the lights work fine... or could the headlight switch be bad...? thanks
05 Flame Red SRT-4
mopar stage 1
msd coil & wires
mopar STS
AGP Dog Bones
JMB Catch Can
HKS turbo timer
Turbo XS HPBC
Injen SRI-Coated Mirror Red by JMB Perf.
JMB Hard pipes with HKS bov
Aftermarket WGA-coming soon
flameredsrt05 is offline
post #2 of 10 (permalink) Old 02-01-2007, 05:37 PM
snkmug's Avatar
Quoted: 0 Post(s)
243 code is the wastegate solenild circuit, and 633 is from the stage one. The 633 will always be there and effects nothing, its there because the skim in the pcm is not programmed....None of this would cause the problems you are having with the wipers...
snkmug is offline
post #3 of 10 (permalink) Old 02-01-2007, 05:38 PM
snkmug's Avatar
Quoted: 0 Post(s)
the 633 will not trip the CE light
snkmug is offline
post #4 of 10 (permalink) Old 02-01-2007, 05:49 PM
New Member
NeoSRT4's Avatar
Quoted: 0 Post(s)
check the connector at solenoid #2 on the airbox... also check the wiring from that solenoid to the PCM as well...
NeoSRT4 is offline
post #5 of 10 (permalink) Old 02-01-2007, 06:56 PM Thread Starter
New Member
Quoted: 0 Post(s)
ok... will check the wiring.. for the solenoid.. any ideas on the switch prob?
thanks
05 Flame Red SRT-4
mopar stage 1
msd coil & wires
mopar STS
AGP Dog Bones
JMB Catch Can
HKS turbo timer
Turbo XS HPBC
post #6 of 10 (permalink) Old 02-01-2007, 10:05 PM
snkmug's Avatar
Quoted: 0 Post(s)
the washer bottle is up there, ,maybe they cut your wires and spliced them back up incorrectly.....
snkmug is offline
post #7 of 10 (permalink) Old 02-04-2007, 08:08 PM Thread Starter
New Member
Quoted: 0 Post(s)
yeah, the cel wont come on till i turn the headlights on... i think they did something to the wires when the installed the new headlight and fog light.. cause my horn won't work either.... and its all triggered by the headlight switch.... when the switch is off everything works fine.... thanks
05 Flame Red SRT-4
mopar stage 1
msd coil & wires
mopar STS
AGP Dog Bones
JMB Catch Can
HKS turbo timer
Turbo XS HPBC
post #8 of 10 (permalink) Old 04-22-2007, 12:24 PM
New Member
Asteroids Champion, Pacman Champion
Quoted: 1 Post(s)
Okay I am experiencing the identical symptoms that flameredsrt05 is/was having.
Someone backed into my car with a Yukon/Tahoe and I had just body panel damage (hood, fenders, headlights, bumper) and I got my car back and now I have to same code P0243 and the same problem with the wipers turning on when the headlights (not parking lights) are turned on.
I have a feeling it has to do with the P0243 code somehow (maybe they are on the same circuit, and there is a problem somewhere in there?)
It can't be a problem with the multifunction switch because like I mentioned the damage wasn't real bad, just some body damage.
Anyone have any other ideas?
flameredsrt05 - Did you ever fix your problem? If so, what was it?
Greg 04-SRT4
Greg_04-SRT4 is offline
post #9 of 10 (permalink) Old 04-25-2007, 12:03 PM
New Member
Quoted: 1 Post(s)
Okay for anyone in the future that experiences these symptoms. It is most likely a bad ground.
If your car was having front end body panel damage work being done, there is a good chance the body shop either left off a ground or put it in a crappy location.
In my case, both of my grounds on the radiator support (near the headlights) were in the right spot, but the body shop put the connector(s) on painted metal so it wasn't grounding properly.
Anyways, I sanded down the paint and reset my PCM, then the P0243 code was gone and the headlights and wipers work like they are suppose to work.
Greg 04-SRT4
post #10 of 10 (permalink) Old 01-06-2017, 08:12 PM
indian srt-4's Avatar
Quoted: 25 Post(s)
Garage
I just had this problem happen today, turn on the lights and boom wipes and left turn light stayed on. Car threw code P0243. Cleared the code with my scan gauge. Turned the car off and back on, everything was fine, until I turned the lights on.... I had to leave the gym and drive home with my wipers on a completely dry night. Once I got on the highway the wipers turned off, I cleared the code again at a stop light. now, the car is fine. I will look for a loose ground in the morning. Funny thing, once the wipers turned off, I had to actually turn them on cause I drove through a rain storm...
Original owner. Purchased 2/19/06 with 6 miles
Juris Doctor, Member of the FL Bar
indian srt-4 is offline
User Tag List
Linear Mode Linear Mode
