Old 03-19-2005, 02:00 AM   #1 (permalink)
Member Number: 21794
Default P0551 cel?
power steering performance? what the hell is that.
JediFrosty is offline   Reply With Quote
Old 03-19-2005, 02:05 AM   #2 (permalink)
SLCFast4's Avatar
Member Number: 12831
Incorrect input state detected for the power steering switch circuit (for PL, high pressure seen at high speed)
SLCFast4 is offline   Reply With Quote
Old 03-19-2005, 02:06 AM   #3 (permalink)
and how do i go about fixing this problem
Old 03-19-2005, 02:07 AM   #4 (permalink)
SLCFast4's Avatar
Have you checked your fluid? Does the steering feel fine?
Old 03-19-2005, 02:08 AM   #5 (permalink)
ya steering feels fine
Old 03-19-2005, 02:12 AM   #6 (permalink)
SLCFast4's Avatar
As far as I know the only thing that is monitored is the fluid level and pump and a CEL is triggered only if there is a problem with those. Do you hear any whine when you turn lock to lock?
Old 09-17-2005, 07:29 PM   #7 (permalink)
Deacon's Avatar
Member Number: 32788
Okay I know this is an old thread, but my engine light just came on and when I check the code I get this P0551.
There's plenty of fluid in the power steering pump. But I haven't had a chance to check the sensor down on the rack.
Has anyone else had this happen?
TRUST THE THRUST
Deacon is offline   Reply With Quote
Old 09-27-2005, 11:24 PM   #8 (permalink)
doc is not i's Avatar
Member Number: 24091
Trader Rating: (10)
I just got the error tonight
doc is not i is offline   Reply With Quote
Old 09-28-2005, 10:41 AM   #9 (permalink)
Deacon's Avatar
Should of posted this earlier, but after I posted my last response I went out and unplugged the harness on the rack and plugged it back in after wiping down the contacts.(they looked ok)
The light stayed on but you have to run thru several cycles before it resets.
And sure enough it went off a couple of days later "after I called the dealer and set up an appointment to bring it in.(go figure)"
Old 09-28-2005, 11:44 AM   #10 (permalink)
Trader Rating: (10)
thanks for the advice, ill try that today
Old 10-01-2005, 01:19 PM   #11 (permalink)
Trader Rating: (10)
Oddly enough my light turned off before I could get to it, however I noticed that the little white cap that was on the valve right next to the power steering contrainer is no where to be found... O_o
Old 10-05-2005, 10:00 AM   #12 (permalink)
Trader Rating: (10)
just got back from the dealer, they said a pressure switch in my rack and peanut steering is done, so they have to get me a new one
Old 10-05-2005, 10:25 AM   #13 (permalink)
Deacon's Avatar
So, let see if I read this right.
The switch to tell you that there's something wrong with the rack went bad. Interesting, so if somethings wrong with the rack then............hmmm.
Sorry, just find that ironic.
Old 10-06-2005, 11:12 AM   #14 (permalink)
Trader Rating: (10)
yea, i will post up whenever the part comes in haha
Old 11-03-2005, 06:26 PM   #15 (permalink)
Trader Rating: (10)
ok i finally had time to go to the dealer, and wow what a difference in handling, i guess the shitty handling grew on me after the problem occured. they said the power streering pressure switch circuit was stuck open...but they replaced the whole rack, it was under warranty so im happy
Page generated in 0.19492 seconds with 11 queries
