Overheating no hot air in car - Page 2 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-25-2013, 04:48 PM   #16 (permalink)
Member Number: 92013
So continue to test drive it and bleed it pretty much
Srt4chode is offline   Reply With Quote
Old 01-25-2013, 04:51 PM   #17 (permalink)
Ridin59vette's Avatar
Member Number: 86347
Yup. Lol It when I flushed mine before winter hit I think it took 5 or 6 cycles.
04 SRT-4: Under Construction
99 9-3: Daily Driver
FS Thread:
http://www.srtforums.com/forums/f416...5/#post9777568
Ridin59vette is offline   Reply With Quote
Old 01-25-2013, 04:58 PM   #18 (permalink)
What temp should I allow it to get to if I'm giving her the good old test ride
Old 01-25-2013, 05:01 PM   #19 (permalink)
they dont need to be long man. A trip around the block and bleed again. Dont let it get too much over 220
FS Thread:
Old 01-25-2013, 05:01 PM   #20 (permalink)
BostonSRT's Avatar
Member Number: 57724
Default Re: Overheating no hot air in car
Quote: Originally Posted by Ridin59vette View Post
You have air in your system still, It can take several test drives and bleeds to get it all out. If your overflow was gurgling it's air in the system.
Min gurgled once during my dilemma. I've been filling it through the over flow then read to fill it from the therm. Housing with the bleeder open and fill till it comes out the bleeder.
Mods: Needswings downpipe catless, 3'' o2 housing, riceplate, FM wastegate, BC coilovers, and DSP 93 octane tune.
BostonSRT is offline   Reply With Quote
Old 01-25-2013, 05:47 PM   #21 (permalink)
Alrighty, thanks for the tips, if I hit any headway after work tomorrow ill def let you guys know! I really appreciate your help
Old 01-25-2013, 09:00 PM   #22 (permalink)
BostonSRT's Avatar
Don't quote me on that I'm not really sure the right way to fill coolant lol
Old 01-25-2013, 09:26 PM   #23 (permalink)
Member Number: 90636
Correct me if I'm wrong but you said it HAD factory orange coolant then you addeed the 50/50 green?if so it's to my knowledge you need to drain it and run either full molar orange or the standard green antifreeze. Due to long term corrosion problems between the two mixxing
Orangeblastn-byu is offline   Reply With Quote
Old 01-25-2013, 10:19 PM   #24 (permalink)
SwinginACR's Avatar
Member Number: 57527
50/50 premix universal was stated a few post up.
SwinginACR is offline   Reply With Quote
Old 01-25-2013, 11:14 PM   #25 (permalink)
Sry ya I didn't see the part where he said he flushed then refilled,thought he said he just mixxed the two.
Old 01-26-2013, 12:05 AM   #26 (permalink)
That's the gunk on my thermostat btw I'm curious if it worked its way into the heat core or other parts of importance
Old 01-26-2013, 07:14 AM   #27 (permalink)
Has anyone else had there themostat looking like that before?
Old 01-26-2013, 09:56 AM   #28 (permalink)
SwinginACR's Avatar
Whats that stuff feel like? It looks alot like the uncured 1775 we use at work to pressure seal the jet.
Something like that could definitely clog something up. A new thermostat would be wise as well.
03' Silver w/05' lsd, 50 Trim, 12.1@107
99' Dakota R/T Intense Blue with only 27K miles
05' SRT-4 ACR T-Totaled 2-24-2008
70' Dart Swinger, 340/auto, Y1 Top Banana
72' Duster, 318/3 speed, FE5 Rally Red
73' Dart Swinger, 318/auto, FE5 Bright Red(my first car)
89' Shelby CSX VNT #477
Old 01-26-2013, 12:41 PM   #29 (permalink)
Way ahead of you on the new thermostat and it kinda felt like silicone I guess would be the best answer, but I heard something about dex cool clotting up and clogging certain things, we are going to do a couple flushes in about a couple of hours and see if we can unblock anything that might be blocked. Will post as soon as it works or not.
Old 01-26-2013, 12:48 PM   #30 (permalink)
SRT of the Month
underSRTarmor's Avatar
Member Number: 32888
Default Overheating no hot air in car
Sounds funny but rinse it out with a garden hose just squirt water in the engine for a long Time
I would pull the radiator out an squirt it out too.
Then fill with straight distilled water. Start car Let it cycle a few times
Drain.
See if its clean or dirty
It still real bad do it again.
But don't put coolant till it clean and ready to fill back the last time.
Sent from
