Overheating no hot air in car - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-25-2013, 03:12 PM   #1 (permalink)
Member Number: 92013
Default Overheating no hot air in car
I just bought this car 5 days ago, it ran like a raped date for the first 2 days.
It started over heating on wensday, it was a cold night 0-15 degrees maybe.
Now to the technical stuff... We changed the thermostat the original one was covered with almost a silicone gunk like they used fix-a-seal, changed the coolant/antifreeze, bleed it from the bleeder.
The mechanic hooked his magic computer thing up to it and it said the intake air temperature senos is reading -40 degrees f idk if that has anything to do with this.
I took it for a couple road tests and it seems to stay at 200 degrees if I beat on her, and if I drive conservatively it over heats.
I also tried a breather test in the radiator and the coolant tank, no sign of co2 present meaning no head gasket issues.
Idk what else I can do. I just bought this car and I'm brokeeeee haha any imput is much appreciated.
Srt4chode is offline   Reply With Quote
Old 01-25-2013, 03:15 PM   #2 (permalink)
Member Number: 90636
Try pressurizing you coolant system and check for leaks.with no heat could be a bad heatr core
Orangeblastn-byu is online now   Reply With Quote
Old 01-25-2013, 03:18 PM   #3 (permalink)
BostonSRT's Avatar
Member Number: 57724
Default Re: Overheating no hot air in car
Sometimes when my car overheats ny heat goes away but then it comes.back if I start driving again. I'm.thinkin it was air in my system. I'm stumped also. I need to get my car pressure tested though.
Mods: Needswings downpipe catless, 3'' o2 housing, riceplate, FM wastegate, BC coilovers, and DSP 93 octane tune.
BostonSRT is offline   Reply With Quote
Old 01-25-2013, 03:25 PM   #4 (permalink)
I can't really take my car anywhere cause I don't want to warp the head and blow a gasket or anything like that, we are going to try and bypass the heater core (which sucks cause it's like sun 20 degrees here, but if that's where the problem is then looks like ill be needing a heater core lol...
Also my heat just doesn't work at all, it worked great the first two days along with the car not over heating but well that all changed
Old 01-25-2013, 03:27 PM   #5 (permalink)
Ridin59vette's Avatar
Member Number: 86347
If it is overheating and your losing heat, More then likely you have air in the system which means not enough antifreeze
04 SRT-4: Under Construction
99 9-3: Daily Driver
FS Thread:
http://www.srtforums.com/forums/f416...5/#post9777568
Ridin59vette is offline   Reply With Quote
Old 01-25-2013, 03:28 PM   #6 (permalink)
OP Did you have heat when you bought the car?
FS Thread:
Old 01-25-2013, 03:49 PM   #7 (permalink)
SwinginACR's Avatar
Member Number: 57527
I would suggest this. When I swapped engines last year I had to start fresh, no coolant what so ever. I filled it, bled it, went for a drive. It tried to over heat about a mile down the road. I turned around and bled it out a couple more times and that took care of it. I was worried that I messed up torquing the head studs down or something like that with the HG.
03' Silver w/05' lsd, 50 Trim, 12.1@107
99' Dakota R/T Intense Blue with only 27K miles
05' SRT-4 ACR T-Totaled 2-24-2008
70' Dart Swinger, 340/auto, Y1 Top Banana
72' Duster, 318/3 speed, FE5 Rally Red
73' Dart Swinger, 318/auto, FE5 Bright Red(my first car)
89' Shelby CSX VNT #477
SwinginACR is offline   Reply With Quote
Old 01-25-2013, 04:19 PM   #8 (permalink)
Very much so, and lots of it, cause the rear passenger window got smashed out
Old 01-25-2013, 04:21 PM   #9 (permalink)
So it worked or it didnt?
FS Thread:
Old 01-25-2013, 04:22 PM   #10 (permalink)
It worked up till wensday morning when it started over heating
Old 01-25-2013, 04:32 PM   #11 (permalink)
What type of antifreeze/water mix did you use? Where are you located?
FS Thread:
Old 01-25-2013, 04:34 PM   #12 (permalink)
There was what appeared to be orange, and I first used 50/50 universal, but I went back and bought the full strength orange and re-did it.
And I'm located I'm Scranton Pennsylvania.
Old 01-25-2013, 04:38 PM   #13 (permalink)
So it's been bitter out. Is the car garaged? Long story short, this sounds like when I had a chunk of Ice in my heater core.
FS Thread:
Old 01-25-2013, 04:44 PM   #14 (permalink)
The night I picked it up it was I put it in the shop where I work once I got it back and began working some bugs out, then I took it home after work, and it was in the cold all night, once I noticed it was above 200 I made a change of plans of where I was going and parked it, over flow tank was gurgling, poured 50/50 premix universal in it, got it to my uncles house began trying to thaw it out thinking it was ice, flushed it filled it with 50/50 uni didn't bleed it the correct way... then today we bleed it through the bleeder practically no air came out... took it for a road test would hit 245 if I wasn't being rough on it, still no warm air...
Old 01-25-2013, 04:46 PM   #15 (permalink)
You have air in your system still, It can take several test drives and bleeds to get it all out. If your overflow was gurgling it's air in the system.
FS Thread:
