Old 06-22-2008, 01:08 PM   #1 (permalink)
Member Number: 57536
Default No boost leak found but only pushing 7 pounds and then it falls to 5
I have done a boost leak test. With the boost leak test I can get it to hold up to like 12 pounds. Check the boost controller sol and it clicked. Ran open waste gate and it ran 15 pounds just fine which is why i don't think there is a boost leak but i can't figure out for the life of me why it will only run 7 pounds. Any idea's?
Rollin22s is offline   Reply With Quote
Old 06-29-2008, 08:10 PM   #2 (permalink)
Wayney_Boy's Avatar
Member Number: 54863
same here, my car is doing the same holding about 5 pounds
New setup: AGP 50 Trim Ball Bearing w/Tial WGA, AGP Race FMIC, AGP CAI, 3"Exhaust w/ATP Test Pipe, ACT Clutch, FTP Motor Mounts, DEI Spray Bar, AEM Wideband, Blitz BC, APexi TT...Numbers coming soon!
Wayney_Boy is online now   Reply With Quote
Old 06-29-2008, 08:17 PM   #3 (permalink)
goats srt's Avatar
Member Number: 47689
reset the pcm by disconnecting the battery for 2 min.
Old 06-29-2008, 08:23 PM   #4 (permalink)
Member Number: 58904
What are your mods? What does your vac lines look like?
04, stage 0,custom 3in o2 housing, 3in dumped exaust, agp log manifold, turbonetics wga, gt3571 turbo, 750injectors, 255 fuel pump, afc neo, engine runup meth injection, STOCK CLUTCH, NO RETURN LINE, 401whp 391tqe. 13.7 @ 118. steet tires. no traction till 4th.
blackgt35rsrt is offline   Reply With Quote
Old 06-30-2008, 12:29 PM   #5 (permalink)
Default Boost problem
I hvae stage two and redid all my vacume lines taking the green hard plastic line and the black hard plastic line out. With a little looking around I swapped my buddy boost controllers cuz he had the same greddy profec I do. And that's what it was. I blew my boost controller. So I went back to the stage two toys and I can run 15psi and it will fall because of a boost leak which I just bought a couple t bolt clamps to hopefully fix that situation.
Old 07-02-2008, 06:26 PM   #6 (permalink)
2FST4YA SRT4's Avatar
Member Number: 55459
I am having same promblem I have a stage 3 with a Turbo XS RFL BOV and a MPX Inter Cooler. Me and my buddy replaced all the vac lines with samco lines and rerouted everything back to the way it was stok except for the BOV line. I am having serious compressor surge, and only able to hold 10 psi no boost leaks or anything.
Please Help with suggestions.
2FST4YA SRT4 is offline   Reply With Quote
Old 07-02-2008, 06:28 PM   #7 (permalink)
goats srt's Avatar
do this^^^
Old 07-03-2008, 04:36 AM   #8 (permalink)
my_little_srt's Avatar
Member Number: 41179
Sam think happen to me while back....Was given the advice to reset the ECU....I did and the problem went away..........
my_little_srt is online now   Reply With Quote
Page generated in 0.23778 seconds with 11 queries
