Old 11-04-2005, 11:39 AM   #1 (permalink)
gotsrt's Avatar
Member Number: 27159
Default New Intercooler issue
Alright I just installed the Quickwhip FMIC and the install went fine until I went to start my car afterwards. The idle on it was rough and very slow could hardly stay alive! What do you think the problem is?
gotsrt is offline   Reply With Quote
Old 11-04-2005, 11:48 AM   #2 (permalink)
shawn_40312's Avatar
Member Number: 27290
Trader Rating: (15)
computer gotta learn the new fmic, start it up a few times and drive it some, it will get better.
Quote: Originally Posted by Zer0
i got pwned by a turbo geo metro so i sold my lebaron!
shawn_40312 is offline   Reply With Quote
Old 11-04-2005, 11:55 AM   #3 (permalink)
gotsrt's Avatar
Thanks man I was thinking to adjust the throttle body but I will give what you said a try. I drove it once and it died on me like twice if I didn't keep my foot on the gas?
Old 11-04-2005, 11:59 AM   #4 (permalink)
Member Number: 28452
something isn't right, make sure your fittings are tight especially the hotside hose to intercooler. Also check vacuum lines, maybe you somehow pulled on off. Do you have a boost leak tester?
Chefskeez6 is offline   Reply With Quote
Old 11-04-2005, 12:02 PM   #5 (permalink)
gotsrt's Avatar
Hot side is on the drivers side right?
Old 11-04-2005, 12:10 PM   #6 (permalink)
blksrt404's Avatar
Member Number: 4798
Trader Rating: (32)
That is the cold side...Hot side is on the passenger side or the other drivers side
blksrt404 is offline   Reply With Quote
Old 11-04-2005, 12:13 PM   #7 (permalink)
gotsrt's Avatar
Thanks bro I just checked the hoses and they are all fine I have the car outside running now to let the computer figure things out but it is still running rough!!!
Old 11-04-2005, 12:52 PM   #8 (permalink)
gotsrt's Avatar
Well still no luck I am kinda lost. I was thinking that the spark plugs might be bad. But how could the intercooler affect that. Well in all actually it couldn't! But anyways if there are anymore ideas hit me up!!!!!
Old 11-04-2005, 01:19 PM   #9 (permalink)
blksrt404's Avatar
Member Number: 4798
Trader Rating: (32)
I dont know if this will help but it cant hurt...Try resetting the PCM....
Old 11-04-2005, 01:20 PM   #10 (permalink)
gotsrt's Avatar
How do you do that?
Old 11-04-2005, 01:25 PM   #11 (permalink)
uberingram's Avatar
Member Number: 447
How do you do that?
By pulling the battery and letting it sit for 5-15 minutes.
Double check all your intercooler hoses and other misc. vacuum lines. If that fails then chalk it up to kick ass coincidence and replace your plugs/wires.
Chris ~ Janky '03
uberingram is offline   Reply With Quote
Old 11-04-2005, 01:46 PM   #12 (permalink)
jacobsen23's Avatar
Member Number: 17081
Trader Rating: (10)
Or you could put your stock IC back on and see if that corrects the problem
jacobsen23 is offline   Reply With Quote
Old 11-04-2005, 02:00 PM   #13 (permalink)
dhardison's Avatar
Member Number: 30245
Maybe your FMIC had some foam peanuts still inside from shipping when you installed it. Mine was FULL of them when I received my QWHIPS FMIC (plastic caps came off). It's possible it pulled one in to the TB. Just a thought........
Dan
dhardison is offline   Reply With Quote
Old 11-04-2005, 02:03 PM   #14 (permalink)
Member Number: 34658
Its a piece....
turbojunk is offline   Reply With Quote
Old 11-04-2005, 02:10 PM   #15 (permalink)
moltenice's Avatar
Member Number: 6528
Trader Rating: (24)
computer doesnt have to learn shit......... There is no way the car would be acting that way after a FMIC install becasue of the computer. If all you did was install the FMIC and didnt touch anything else then the problems lies there. You have checked and have no boost leaks, or loose pipes, so the only other thing i can think of like mentioned above is the peanuts that come in the box.. maybe some went up stream, possibly getting stuck in front of the TB..
Sounds like to might have to tear some stuff apart......
moltenice is offline   Reply With Quote
