Old 11-05-2003, 11:46 PM   #1 (permalink)
Less's Avatar
Member Number: 5090
Default Mopar BOV
I just installed a mopar bov on my 04, when i boost an let off it makes a loud pshhhhh then a bunch of little ones before it goes quiet, i dont think its acting right anyone else having this prob?
Less is offline   Reply With Quote
Old 11-05-2003, 11:51 PM   #2 (permalink)
Slvrstreak's Avatar
Member Number: 626
well mine, if i'm shifting normal underboost, it makes a psh psh psh..little burst of the air shotting out. that is normal because the butterfly in the throttle body is opening and closing simultaniously (spell check) as you shift. is that what you were talkin about?
03' Dodge SRT-4
05' Subaru STI
"SEYAH"
Slvrstreak is offline   Reply With Quote
Old 11-05-2003, 11:57 PM   #3 (permalink)
qwiksilvertrav's Avatar
Member Number: 360
I have the same type of thing on mine. It makes the initial loud pssh, and then the pssshhh keeps going, but a lot softer and it keeps going for a while sometimes. It usually happens when you're on the gas. I haven't noticed less boost or any problems so I figured it's normal.
DCR Stage 3 w/ TT's
Form & Function EM Port + Cer Coat
AGP DFFMIC
AGP S3 wga
DCR Intake manifold
DCR TB
ED hardpipes
Greddy Type RS BOV
B&B's TB 3' Exhaust no cat
Maxxfabb S3 O2 housing Cer coat
Psi Fi Intake
Perrin STS w/ BB's
Prothane MM inserts
AEM Uego Wideband
Interceptor Scan gauge
Drag DR2 Gunmetal 18's
Blitz Fatt-3 TT
Phillips Ultinon 6k HID's
Eibach Springs
More!
www.mnsrt4.com
qwiksilvertrav is offline   Reply With Quote
Old 11-05-2003, 11:59 PM   #4 (permalink)
canadian_srt4's Avatar
Member Number: 413
Trader Rating: (30)
that doesn't sound normal to me? I don't get that sound with mine.
canadian_srt4 is offline   Reply With Quote
Old 11-06-2003, 12:41 AM   #5 (permalink)
Less's Avatar
Member Number: 5090
yea i got the same sound as what you guys are talken about the pshhhh, then little pshhh, pshhh, pshhh. i didnt think it was normal cause i heard the sound of it from a link in here an it sounded alot nicer!
Old 11-06-2003, 12:45 AM   #6 (permalink)
turbo4life's Avatar
Member Number: 666
I thought the same thing, appearantly it is normal. You can hear a pssh nice n loud in any gear if you are crusing and then get on and off the throttle real quick.
Quote: Originally Posted by Dale Seeley
turbo4life, are you related to lifeisdeath?
If you have nothing to offer the thread, other than your incredible ability to toss around inane opinions, please step up to the plate...
Dale
Quote: Originally Posted by bodizapha13
The first night wasnt to bad. He had on all his clothes during back rub. It was the next day when he came out in a thong already oiled up that I had to call in Tim's help. He knows how to "handle" Dale.
turbo4life is offline   Reply With Quote
Old 11-06-2003, 08:03 AM   #7 (permalink)
Stealth's Avatar
Member Number: 742
If your on the gas in vacum..at around -10 you will hear a pshhhhh for a good 3 seconds or so. Don't worry about that it happens...
But the if its going pshhhhh stops..then goes again...that's not good. It's not supposed to stop and go like that.
2003 Black SRT-4
Stealth is offline   Reply With Quote
Old 11-06-2003, 08:38 AM   #8 (permalink)
cali's Avatar
Member Number: 159
Default Re: Mopar BOV
Boost controller? Teed into the blue line?
someone is watching me
Old 11-06-2003, 04:47 PM   #9 (permalink)
Member Number: 360
Mine doesn't stop and go at all. It'll just make the initial pssh, then just keeps goin and gets softer and softer. Like I said, I haven't noticed any difference before or after and get the same boost. If it stops, then goes again without putting on the gas again, then somethings screwed up.
Old 11-06-2003, 05:05 PM   #10 (permalink)
Less's Avatar
Member Number: 5090
no it doesnt completely stop its a loud flutter sound. there is only 1 way to put it on isnt there, maybe if i flip it to the other side or something? yea and i have no problem boosting but it doesnt quite have a bov sound to it, and i have no boost controller
Old 11-07-2003, 12:30 AM   #11 (permalink)
Member Number: 360
If you have a flutter to it, then there's something wrong. You should have a pssshh all the time.
You might have it to loose. Try to torque the bolts down a little more. Tourqe spec is in the manual. This is the way you should've faced the bov plate: http://www.srtforums.com/howto/moparbov/ go to step 11.
Old 11-07-2003, 06:30 PM   #12 (permalink)
Kevron's Avatar
Member Number: 2866
If the valve flutters, that means that your turbo is getting spun backwards. This is bad since that is part of the reason you even have a BOV. Turbo's are NOT supposed to spin backwards.
Chrome polished muffler bearings, oil gapped at 23, Hyfrenufren gauge, fuel injected brake lines, Fully synthetic blinker fluid, and a dream to keep me going.
Kevron is offline   Reply With Quote
Old 11-07-2003, 07:07 PM   #13 (permalink)
Member Number: 360
You think it's spinning backwards? What would be causing that? As in what should he do to fix it?
Old 11-07-2003, 07:28 PM   #14 (permalink)
Member Number: 3908
our turbo's do spin backwards not forward <clockwise>,make sure that you installed the bov plate correctly. when you look at the bov from the top do you see 2 holes at the top of the bov? if not maybe its facing the right way but you need to spin it around so the smiley face is lined up with the turbo housing.
YAMKOG is offline   Reply With Quote
Old 11-07-2003, 07:52 PM   #15 (permalink)
bmxfreak's Avatar
Member Number: 382
w/o stage 1, the bov leaks for a long time it seems. S1 fixed it for me...much shorter pshh
Dont listen to me, i'm just a mechanic
bmxfreak is offline   Reply With Quote
Page generated in 0.21722 seconds with 13 queries
