Old 11-08-2004, 12:43 PM   #1 (permalink)
BOOSTEDSRT2004's Avatar
Member Number: 11605
Default Missfire Cylinder 4 Hhhheeellppp Bad Idle
hI , GUYS WELL I have a problem with my car , i have an safc 2, new msd wires, plugs, stage 2 injectors and walboro fuel pump upgrade, 2.5 turboback , AGP wastegate and my car at idle feels like it missfire and it does i am getting a code 304 which is missfire in cylinder #4 but i dont understand where this is coming from please help me.
ALWAYS BET ON WHITE
BOOSTEDSRT2004 is offline   Reply With Quote
Old 11-08-2004, 12:46 PM   #2 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
check your plugs first.
how much boost are you running? stage 2 injectors, pump and safc2 for an agp wga and exhaust as mods?
anyways, check your plug gaps, how much boost are you running?
Old 11-08-2004, 12:54 PM   #3 (permalink)
bodizapha13's Avatar
Member Number: 10558
Trader Rating: (17)
If it is the plug and you want to give the dealership a try there is a TSB out about the number 4 plug and wire. They will replace all 4 plugs and put on new wires under the TSB. Let me know if you want a link to it.
bodizapha13 is offline   Reply With Quote
Old 11-08-2004, 01:09 PM   #4 (permalink)
im spiking about 20 dropping to 15-16 to redline, my gap right now is .50 and they are brand new plugs.
Old 11-08-2004, 01:10 PM   #5 (permalink)
and also i went to the dealer for the tps sensor and was fixed about 2 months ago.
Old 11-08-2004, 01:10 PM   #6 (permalink)
NIVO88T's Avatar
Member Number: 1109
drop your gaps down to .038" and start from there...
Old 11-08-2004, 01:11 PM   #7 (permalink)
Mopar Event Specialist
Dale Seeley's Avatar
Member Number: 150
The gap is high, as is probably the attempted boost.
After regapping the plugs to what Nivo will recommend (.035 probably), you'll still be saddled with the PCM trying to save your engine from your attempts to blow it up....
Street Ricers Unite! We've been persecuted too long.
Dale Seeley is offline   Reply With Quote
Old 11-08-2004, 01:12 PM   #8 (permalink)
NeonDan's Avatar
Member Number: 138
Trader Rating: (69)
check the coil....
Built by experts. Tested in the real world.-Mopar
For sound Install/Tuning assistance: (727)512-9684 or PM
Now serving Upstate SC/N. GA SRT4 community
<---My modest 305fwhp "project" car in progress
NeonDan is online now   Reply With Quote
Old 11-08-2004, 01:15 PM   #9 (permalink)
ok i had the gap at .35 and it still did it, also i tried my friends srt coil and it was the same thing. ?
Old 11-08-2004, 01:16 PM   #10 (permalink)
NIVO88T's Avatar
Member Number: 1109
now it's obvious to check the wires....
Old 11-08-2004, 01:18 PM   #11 (permalink)
Member Number: 929
Quote: Originally Posted by NeonDan
check the coil....
What he said after regap of plug if problem still exists.
gliv is offline   Reply With Quote
Old 11-08-2004, 01:20 PM   #12 (permalink)
Member Number: 929
Are your plug wires in the correct order? Hey it could happen.
Old 11-08-2004, 01:20 PM   #13 (permalink)
teh problem after regapping he plugs still exists and i have new wires with the new plugs i bought them the same day. it did it with the old wires and it does it with the new ones too.
Old 11-08-2004, 01:23 PM   #14 (permalink)
NIVO88T's Avatar
Member Number: 1109
check your safc settings. what are they?
Old 11-08-2004, 01:29 PM   #15 (permalink)
im running a pressure sensor set up with the in 05 and the out 05 does anyone know the setting for the SAFC2 for the srt ??
Page generated in 0.20915 seconds with 13 queries
