Old 02-19-2008, 04:52 PM   #1 (permalink)
slim26's Avatar
Member Number: 33311
Default Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage ?????
What does that mean? I threw that code today.
slim26 is online now   Reply With Quote
Old 02-19-2008, 04:59 PM   #2 (permalink)
stageII's Avatar
Member Number: 32588
Trader Rating: (35)
do you have any wiring going to the intake manifold sensor (map sensor) if so check the wiring asap. You also can test it this way go over 80 mph for like 2 to 10 min and you will start dumping fuel that would mean map is out of service happened to me. got a new one stage 2/3 from mopar center 80 bucks. But more then likely it is a wire to the map check that first
All DCR ALWAYS TUNED BY TURBOTUNE (MARK)
New Best1/4 11.52 at 123.00 mph at 26psi
HERE IS THE VIDEO
http://videos.streetfire.net/video/1...390_189672.htm
NEW Best 1/8 7.45 at 100.25 mph at 26 psi
stageII is offline   Reply With Quote
Old 02-19-2008, 05:00 PM   #3 (permalink)
Discussion/Performance Mod
NoisufnoC's Avatar
Member Number: 136
you arn't tying to add fuel w/ your DTEC are you?
omgz!! i haz mods!!
Old 02-19-2008, 05:47 PM   #4 (permalink)
slim26's Avatar
I just hooked up the dtec again, well it was hooked up my DCR, but my dtec was bad and i sent it to get it reflashed and just got it back today, But my maps are all screwed up. So can someone help me get it right?
Old 02-20-2008, 01:46 PM   #5 (permalink)
slim26's Avatar
I dont think so? My map was all at 0.0, but my injector duty was at ---. Does that mean anything? Ok my map is set right now as -14 from 500 to 2500RPM -13 from 3000 to 5000RPM and -12 the rest of the way down. On 25% 50% 75% and 100%. Does this sound correct? Because i am affraid to start my car, last time i did, it boaged down and shut off.
Page generated in 0.16235 seconds with 13 queries
