Old 03-14-2006, 11:32 PM   #1 (permalink)
Member Number: 39469
Question Low Boost Only 10-12psi Max HELP!!!!
Whats up everyone, my friend has a 04 SRT-4 and is only getting 10-12 Psi Max. There is no check engine light on and there seems to be no leaks. Installing a "T" fitting only allows it to go to 15psi. Another friend has the same problem with his 05 SRT-4 and he has Stage 2 w/o toys and is still only getting 10-12 Psi Max. Any idea whats goin on with these things? Anyone else have this problem with their car? Any info is greatly appreciated. Thanks Guys.
1HotNeon is offline   Reply With Quote
Old 03-16-2006, 10:00 AM   #2 (permalink)
Member Number: 29796
change your boost gauge!!!
Conanlove1 is offline   Reply With Quote
Old 03-18-2006, 02:35 PM   #3 (permalink)
My friend with the 04' has been through 2 already cause they keep breaking and just put his 3rd in last week. Any other ideas what it could be?
Old 03-18-2006, 02:42 PM   #4 (permalink)
Ghost's Avatar
Member Number: 2060
cold weather does this. the ecu lowers boost in cold temps to gain the the same air at hot temps. waite till spring and @70 de your friends will see higher boost levels w/ no gain of power. remember cold air is more dence and reqires less psi for same result in power.
Ghost is offline   Reply With Quote
Old 03-19-2006, 04:51 PM   #5 (permalink)
Member Number: 26496
Lightbulb
Cold weather & just reset pcm by disconnecting battery, works for me!
scotsese is offline   Reply With Quote
Old 03-19-2006, 11:01 PM   #6 (permalink)
Member Number: 22384
10-15 psi is a stock boost level...
Devoted!
Devoted04 is offline   Reply With Quote
Old 03-20-2006, 06:15 PM   #7 (permalink)
Hey guys!!! Thanks for your responses. I have an update on the problem with the car. I drove the 04' myself today and the boost gauge needle hit 10psi and started shaking bad and wouldnt go past it even when flooring it in 3rd or 4th. The boost gauge is brand new, 1 week old. He resets the computer and it doesnt help. I am thinking that possibly the computer is shot. Anyone else have any other ideas of what we can check?
Old 03-20-2006, 06:19 PM   #8 (permalink)
Ghost's Avatar
Member Number: 2060
that has nothing to do w/ ecu. reseting will not be nesseary. it is a mechanicle boost gage. any stang nosies? what is your friends mod list, and vacume line set up?
Old 03-20-2006, 06:21 PM   #9 (permalink)
mm_omega2's Avatar
Member Number: 12781
I am having a similar problem myself. My car usually hits/stays around 14-16psi. Today I cleaned the K&N filter, changed to NGK Vpower plugs, and flushed and changed the coolant. Just took it out to make sure the plugs were fine and not spark knocking or anything. Now I am boosting 10-12 Max.
I reset the computer and what not and the car seems to have better throttle response and boost coming on quicker than before yet still only hitting 12psi.
Boost isn't fluttering around like before so everythings seems perfect....I just miss my higher boost.
mm_omega2 is offline   Reply With Quote
Old 03-20-2006, 10:11 PM   #10 (permalink)
bad boost gauge guys.. sure of it, i had the same problem..
hear a rattle when giving throttle, but only in boost..
changed the gauge and gone.. oh ya, my guage was only 2 weeks old...
Old 03-21-2006, 05:57 AM   #11 (permalink)
Ghowie's Avatar
Member Number: 33090
Trader Rating: (55)
It's the cold weather! Ecu lowers boost when it's cold it's not the boost gauge wait untill it gets warmer you'll see!
Ghowie is offline   Reply With Quote
Old 03-21-2006, 09:46 AM   #12 (permalink)
Member Number: 28737
Trader Rating: (67)
Could have a boost leak. It isn't always the cold or the gauge. I was hitting 17 and then 5 minutes later I was at 10. Needle shakes bad if you try to get any more boost out of it. But with mine you can hear my massive boost leak until you try to do a test on it. When you test it, you can't hear the air coming out anywhere. Start checking everything for leaks. The vac lines, intercooler pipes, make sure everything is plugged in. You'll find it eentually. I still can't find mine but only been looking for a couple days. Might be going to stock slowly to find the problem
taco is offline   Reply With Quote
Old 03-21-2006, 07:00 PM   #13 (permalink)
My friends mods are only the Mopar cold air intake, MPx 3'' O2 housing and a Corsa exhaust. We took out his Turbo XS Bov to make sure it wasnt leaking there and put on the stock bov. Everything else is stock and nothing leaking. The car does make some popping noises at w.o.t. sometimes, almost like its cutting out and breaking up.
Old 03-27-2006, 11:28 PM   #14 (permalink)
Hey guys!! I have an update.We might have found the problem!!! My friend flashed an update into his pcm at work today and now is running 12-13psi consistantly and the car feels back to normal. Hopefully it will be ok now. I will let you guys know how things work out. Thanks for all the responses. Later.
Page generated in 0.21805 seconds with 13 queries
