<Well , I've been driving all over and I have to say it seems the Cam sensor plug was the issue. Keep an eye out for that coolant leak right above the connection. Thanks for the responses and ideas >
With just over 40k miles I’ve started having problems with the car losing power and bucking wildly at neutral throttle settings and at varying speeds. It’s happened in 3rd, 4th, and 5th gears and will go away as soon as I mash the throttle.
Here’s what I’ve checked / replaced. Checked intake manifold gasket (visually), checked TPS wiring (Wiggled connector while engine idling with no apparent RPM change), replaced plugs and gapped correctly, replaced wires, cleaned and re-oiled K&N. Thought it was a tank of bad gas (H2O) and went through two bottles of dry gas. No luck.
I have S2 w/o toys and have never had any issues with the car. With new plugs and wires it pulls so very hard in every gear and runs very strong. It’s just when you cruise at any speed and just maintain a low throttle setting it develops this bucking.
The symptom is very similar to when someone is just learning on a manual transmission and doesn’t work the clutch and gas right and comes close to stalling it.
I’ve searched the forums and can’t seem to find exactly the same symptoms. Looking for any help or direction. With S2, don’t want to take it in to the dealer (I do have an extended warranty) just yet; and not sure if they would honor it with the S2.
One thing I haven’t checked / replaced is the coil pack. I know that takes a lot of heat from the turbo but it’s so damn intermittent and runs so strong otherwise, it’s hard to believe it’s the coil.
Thanks for and feedback !
