Old 03-18-2008, 01:38 PM   #1 (permalink)
Member Number: 62539
Default I Need Help Please
My car is sputtering at full throttle. i havent gapped my plugs. has anyone else had this problem? what do you think it could be? thank you.
norcal209_srt4 is offline   Reply With Quote
Old 03-18-2008, 01:43 PM   #2 (permalink)
quicky4's Avatar
Member Number: 28222
Well, are you still boosting normally or is there no or little boost?
682hp, 599tq
Best e/t 10.51
Best trap 138mph
100% RAGE BUILT
SRT-4 Manual 5spd record holder. Full Weight and then some.
quicky4 is offline   Reply With Quote
Old 03-18-2008, 01:44 PM   #3 (permalink)
boosting at 10psi
Old 03-18-2008, 01:49 PM   #4 (permalink)
it still boost but if i give it full thottle it cut out. or if im at 5gear and punch it cuts off
Old 03-21-2008, 10:27 AM   #5 (permalink)
Member Number: 14181
Unhappy
so did you ever firgure out what was the problem. because i am having the same exact problem with mine right now. it happened after i put new plugs in it. i put the ones befor eback in a still having the problem. i thought i might have got a bad tank of gas cause i filled it up that morning as well. but i have filled it up since then and still having the same problem. i have also tried to reset it. but still same.
srtstomper is offline   Reply With Quote
Old 03-21-2008, 11:38 AM   #6 (permalink)
Member Number: 11520
I had a similar problem because the spark plugs were misfiring due to age. I just replaced them and that fixed the problem.
2004 E-Blue
Current Mods: AGP Stg 3 Delta 44 lb kit, Stage 2 w/o toys, SCT flash, DCR Oil Mod, MPx Turboback 3" exhaust w/cat, SBC Stg 3 clutch, DTEC FCBC, Psi-Fi Oversized IC, AGP UHP, AGP LHP, HKS BOV, AGP 3 inch CAI, AEM UEGO, AGP Motor Mounts, Hotchkis sway bars, Tein SS, 245 tires
New: 358 whp, 364 wtq, pump gas and nothing else
SRT-4owns is offline   Reply With Quote
Old 03-24-2008, 12:04 PM   #7 (permalink)
I GAPPED my plugs to 0.035 it helped a little bit but it still does it. this sux
Old 03-24-2008, 12:16 PM   #8 (permalink)
S2R0T044's Avatar
Member Number: 5620
Look into coil or wires. Are you both running the stock coil? Are you both on stock wires? If so, how many miles? If not, what wires?
Could potentially be your fuel pump too or some dirty injectors.
Josh - 2005 Black SRT-4
Drastic.
blazinsrt built.
WTB: DTEC FC
S2R0T044 is online now   Reply With Quote
Old 03-25-2008, 02:22 PM   #9 (permalink)
IM using the stock coil and my car has 50k miles with msd wires. i have the msd coil with less miles wick one should i use ?
Old 03-26-2008, 07:11 PM   #10 (permalink)
bumble_bee_srt-4's Avatar
Member Number: 56601
the MSD wires tend to suck. i would swap out the coils and see if it continues, if it does then its ur wires, if not, then u solved it. i had the same problem but it turned out to be my MSDs so i changed them to Mopar performance ones and workes fine
bumble_bee_srt-4 is offline   Reply With Quote
Old 03-30-2008, 12:14 AM   #11 (permalink)
Ill Try It Thanx For The Help
« Tps? | help please »
Page generated in 0.21559 seconds with 11 queries
