Old 11-06-2009, 05:48 PM   #1 (permalink)
Member Number: 63342
Default how do i get this to stop
ok, so for about 6 months or so now, i am always getting a P0133, O2 slow response, code and it keeps coming back. i reset the PCM pretty much every time it pops up and it keeps coming back. and for those of you that tell me to change the sensor, i am on my third one. i have done everything that i can to try and fix this problem to no avail. i have tightened every single exhaust bolt and still nothing. and the weird thing about it is that my a/fs are fine in the 14.0-14.2 range. also it always pops up while cruising.
anyone have any suggestions other than what i have already tried?
thanks
E1 turbo, PTP pnp e-mani, FM wga, 3" O2, 3" DP, 2.5 DP back exhaust, full 2.5" IC piping, Boomba BOV w/13psi spring, AEM SRI, NGK plugs, MSD 8.5mm wires, AEM uego WB, Spearco DFFMIC, race motor mount inserts, ACT 6 puck, Maddog 80% sts;
best dyno 307whp/301wtq @ 19psi
13.676 @ 106 on 20spike, 16-17 redline.stocker
13.45 @ 103 ~18psi spike, 16 hold. pcm boost/stock WG
E1 at ~23psi 13.43 @ 111.65 w/non pcm boost(can't launch/no driver mod ftl)
1fast4 is offline   Reply With Quote
Old 11-06-2009, 08:12 PM   #2 (permalink)
Icecreamman's Avatar
Member Number: 39828
Trader Rating: (21)
Check the wiring that goes back into the harness. Since its slow response I'd guess that the heater in the 02 sensor isn't working properly. Could be that the wire from the 02 sensor after the clip is bad. When you replaced the sensor, did it fix the problem at all? Like it goes away for a while and then comes back after a while? The wires could be crossed somewhere causing the heater to go bad before long. I'd follow the wires back into the harness to see if you can find any visible faults. Hope this helps.
Icecreamman is offline   Reply With Quote
Old 11-06-2009, 08:20 PM   #3 (permalink)
Member Number: 41638
Exactly. Start tracing wires.
05#191 is online now   Reply With Quote
Old 11-06-2009, 09:00 PM   #4 (permalink)
i was afraid someone would say that. from a quick glance all of the visible wires that you can see when you are looking at the sensor look good, the connectors look good. maybe i will see if i can just replace the wire harness for that and see if it fixes the problem. thanks guys.
Page generated in 0.12227 seconds with 13 queries
