just installed the toys and the HOM light dident stay on at first but now it just stays on.............. and the IC sprayer light worked when i would hit the gas then it would go off............. but now it just goes on when i hold the button.
i installed just installed the toys and the HOM light dident stay on at first but now it just stays on and the IC sprayer light worked when i would hit the gas then it would go of but now it just goes on when i hold the button.
Edit this please, its hard to read and understand = its too confusing and too hard to interpret in order to understand what was done and whats now happening.
just installed the toys and the HOM light dident stay on at first The toys were installed and when HOM was activated it was solid but when driving it it started blinking? but now it just stays on now when you activate it and then drive the car and it stays solid?.............. and the IC sprayer light worked when i would hit the gas then it would go off............. but now it just goes on when i hold the button. The IC sprayer worked on auto when you first installed it but now the IC sprayer only works when its manually activated?
The HOM light is always on, but dim. Hit the button....It should get brighter.
Also, the IC switch is a three position switch. Off, PCM control, and on. It is spring loaded to the PCM control, and when in that position, will only come on when the PCM does a bunch of calculations and deems that it is needed.
My vehicles:
2003 Flame Red SRT-4 SOLD!!!!
2007 Charger SRT-8 (black)......
2005 Nissan Titan.....stock
Ok sry for makin this hard i installed the turbo toys after installing(injectors,wga,map, tip,ecu) when the toys were installed they IC sprayer worked right for about a day. And when i mean right i mean when i would hit the gas the little blue light would come on and when i would hold the button it would stay on for a sec or two. But now the light will only go on when i hold the IC sprayer button. Now for the HOM when i first installed the light wasent on but now the light just stays on i tried putting HO in and hoping it would shut off but nothing. the only thing i get is when i turn on my car it turns off then on and stays on. Hope this help clear it up.
when i first installed my turbo toys, the HOM light was always on. but that was because i switched the wires from the DAB to the HOM port in the PCM connector. so when the car is on, DAB is activated in the PCM but the wire is connected to HOM in the cabin, turning the HOM light on all the time. Another thing you should check is making sure you DAB actually works. If so, then check all your wiring again. that would suck. but maybe this helps.
