Old 04-21-2008, 10:17 PM   #1 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (24)
Default High Speed fans intermittent with A/C operation
Does anybody have any idea what would cause this? Today I pulled into the Wally World parking lot to get some stuff, and I noticed my coolant temps were 205 on the scan gauge, with my A/C on, with a 180 t-stat in. I popped the hood and both fans were on, but were on low speed only. As soon as the coolant hit 214, the high speed fans kicked on, but I'm assuming its only cause the coolant reached that temp and not because of the A/C. The fans returned to low speed once the scan gauge indicated 195.
Does anybody have any idea what can be causing this?
Old 04-22-2008, 09:23 AM   #2 (permalink)
Philth's Avatar
Trader Rating: (24)
Morning bumpage...
Old 04-27-2008, 04:14 PM   #3 (permalink)
Member Number: 60156
check the relays and the rad fan fuse
Panco469 is offline   Reply With Quote
Old 04-27-2008, 04:16 PM   #4 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (49)
What speed did you have the A/C on? 1 and 2 settings the fans come on at a low speed, and 3 and 4 they will be on high.
ASE Certified Automotive Technician
Old 04-27-2008, 10:58 PM   #5 (permalink)
Philth's Avatar
Trader Rating: (24)
Does it say this somewhere? Reason why Im asking is that I believe my high speed fans have been known to come on setting 1 and 2 as well...
Old 05-06-2008, 04:45 PM   #6 (permalink)
srt4chris401's Avatar
Member Number: 10362
There are 2 places for temps "I believe". The 180 t-stat only works for allowing the radiator fluid to flow as soon as the temp hit's 180. The fans I believe run off a different setup, mainly all hooked in, and controlled by the pcm. That's why there are a few write ups to bypass, or force the fans into high speed mode...Correct if i'm wrong...
SRTOC-521
srt4chris401 is offline   Reply With Quote
Old 05-06-2008, 04:46 PM   #7 (permalink)
Philth's Avatar
Trader Rating: (24)
Yeah I've come to the conclusion that I will have to just upgrade my aeroforce gauge for the instant high speed fan on function.
Old 05-06-2008, 04:54 PM   #8 (permalink)
NoisufnoC's Avatar
Member Number: 136
My fans come on at 185
omgz!! i haz mods!!
Old 05-06-2008, 04:55 PM   #9 (permalink)
Philth's Avatar
Trader Rating: (24)
But your on the SCT nutsack..
Old 05-06-2008, 04:56 PM   #10 (permalink)
NoisufnoC's Avatar
Member Number: 136
Just saying....
Old 05-06-2008, 05:00 PM   #11 (permalink)
Philth's Avatar
Trader Rating: (24)
LOL ass
» Search Used Cars
Page generated in 0.23985 seconds with 11 queries
