Old 06-25-2008, 02:16 PM   #1 (permalink)
rwr1011's Avatar
Member Number: 47366
Default High engine temp!!!!
Basically what I need to know is how to bleed air out of the cooling system, by the thermostat, because I have heard that could be the problem to my high temps. I just replaced the thermostat and radiator cap so I know it is not one of the two. So if someone could guide me through this I would appreciate it
Thanks
Black 03 - 05 Transmission
Forge WGA, TurboXS RFL, S1 injectors, Injen DP, Greddy TT, Mopar CAI, TEIN S-Techs, MSD Wires, 3in MPX TBE, AGP UHP, AGP LHP, NKG Plugs, AEM Wideband, SAFCII, Boomba IMG, Maddog 80%, Pwerks Shift Selctor
rwr1011 is offline   Reply With Quote
Old 06-25-2008, 02:25 PM   #2 (permalink)
PsychoSRT05's Avatar
Member Number: 28174
-Get a small tube over the bleeder screw on the t-stat housing.
-With the engine cold, open the cap.
-Put the tube(must be long, about 2 feet or so)in a bucket to catch fluid.
-Open the bleeder using a 10mm wrench
-Pour fresh coolant into the t-stat housing and watch for the level to rise.
-Let the level fall back down, then repeat.
-Repeat until you get a smooth flow of coolant out the tube into the bucket catching the coolant.
-Close the bleeder
-Put the cap back on
All done!
2004 Silver SRT-4
Mods: Stage 2 w/o Toys, Full 3" Exhaust, AGP FMIC, AGP LHP, PTP UHP, PTP Charge Pipe, Injen SRI, Mopar BOV, PTP WGA, Ported TB, MSD Wires, 180 T-stat, 22 PSI rad. cap., AEM UEGO, PTP Check Valve, Race MM Inserts, Iridium IX Plugs, AGP Catch Can, Eibach Pro-Kit, JMB Coil Heat Shield
PsychoSRT05 is offline   Reply With Quote
Old 06-25-2008, 02:27 PM   #3 (permalink)
ibnzmonkey's Avatar
Member Number: 36611
Trader Rating: (13)
good info, i need to do this when i get home. Ive read that the car needs to be turned on though. does it matter?
Quote: Originally Posted by uncommon© View Post
that hood is as aerodynamic as a sail on a Failboat
ibnzmonkey is offline   Reply With Quote
Old 06-25-2008, 02:31 PM   #4 (permalink)
I would do this only when the motor is cold and off. I may be wrong though. That's how I did it tho.
Old 06-25-2008, 02:37 PM   #5 (permalink)
STUDLEE1A's Avatar
Member Number: 54852
uhh.. if you do it when the motor is off... the T-stat will be closed... i just start the car with the cap off and wait til it gets to operating temps... then the t-stat will open and you can top off your fluid... dont forget to use the special dodge fluid and be prepared for the yummy coolant smell as your overflow pushses out any extra within the next few days...
Factory Freak
STUDLEE1A is offline   Reply With Quote
Old 07-02-2008, 03:49 PM   #6 (permalink)
rwr1011's Avatar
Thanks I finally have some time to try this tonight. But I found that my engine only heats up when its stopped sitting still, when I start moving it will go down again, does anyone have any other ideas???
Old 07-02-2008, 03:58 PM   #7 (permalink)
STUDLEE1A's Avatar
you want it to heat up with the cap off... that way the thermostat will open and burp the air out... as long as you take the cap off with it cold before you start it, it wont bubble out...
Old 07-02-2008, 06:12 PM   #8 (permalink)
rwr1011's Avatar
STUDLEE1A I just did what you said to do and my coolant would just pour out of the housing after a few seconds...
Old 07-03-2008, 11:13 AM   #9 (permalink)
STUDLEE1A's Avatar
did you open it when it was cold or warm? i have always done this with my car when i flush the coolant.. never had a problem...
Old 07-03-2008, 11:18 AM   #10 (permalink)
rwr1011's Avatar
Yea maybe it wasn't cold enough, but I also heard it could be because my fans weren't coming on, so I'm going to go up to Dodge today to try to get the fuse I need.
Old 07-08-2008, 08:20 PM   #11 (permalink)
rwr1011's Avatar
BUMP my engine is still overheating, only when i am stopped though. Can anyone give me some advice?
Thanks
Old 07-08-2008, 08:25 PM   #12 (permalink)
Do you know for a fact your fans are workin'? Both high and low speed?
Old 07-08-2008, 08:34 PM   #13 (permalink)
slyder's Avatar
Member Number: 36768
Trader Rating: (67)
What is your engine temp at????
Mine gets warmer at stop as you have reduced the air flow over the cooling fins of your radiator. The fans at high speed can still only pull in so much air.
Have you checked the mix of the coolant with a hydrometer, this is mainly for the freezing point but it will also tell you if you have the right 50/50 mix. Your mix may be wrong.
Worst case you can REMOVE the thermostat. This will ensure the engine is always getting the coldest coolant. If your temps drop and it stops overheating you may have a bad thermostat.
Just some simple things to try,
Good luck,
Slyder
slyder is offline   Reply With Quote
Old 07-08-2008, 11:47 PM   #14 (permalink)
Member Number: 59082
Make sure the fans are turning on. They should turn on around 205 and shut of just below 200. They should always be on when the a/c is on, (good way to check if they are working) if they arent working, check to make sure they turn freely then check your fuses and relays and replace if they are blown..
good luck.... I just went through the same problem only it was self inflicted due to a multi plier tool sheath getting stuck in my fan shroud that i had left under the hood.
cla2031 is offline   Reply With Quote
Old 07-09-2008, 09:21 AM   #15 (permalink)
westhemess's Avatar
Member Number: 64947
Default Same Prob
I had my engine the other day beep becuase it was on the red line on my guage :S when i was stopped, then it went back down...i dont think its ever seen 90 degress C* in city driving. could that have something to do with putting 5W40 in this blazing hot weather?
westhemess is offline   Reply With Quote
Page generated in 0.19206 seconds with 11 queries
