Old 11-14-2008, 11:49 PM   #1 (permalink)
Member Number: 65084
Default help please!!!!
still the same problem goin on.sounds like a wrx horrible idle when i drive the car it dont clear out at higher rpms sounds like its running on two cylinders. put a new cam sensor on it and nothing. new wires and plugs and they are gapped and nothing. pulled out injectors turn the key on and nothing came out. so they are not stuck open. is there any way they could be clogged? and how do i check that?
blueSRT4me is offline   Reply With Quote
Old 11-14-2008, 11:54 PM   #2 (permalink)
dj2
dj2's Avatar
Member Number: 28474
Trader Rating: (28)
sounds like mine did when I had a bad injector, you can send the to deatschwerks here in OKC, they are a vendor here on the forums. They tested mine and provided individual flow charts for each injector, they will clean them if they can.
“They [liberals] feed your animosity toward the rich - as if a poor person can get you a job.”
dj2 is offline   Reply With Quote
Old 11-15-2008, 12:03 AM   #3 (permalink)
so would you recommend i try a set of stockers from a local?
Old 11-15-2008, 01:31 AM   #4 (permalink)
dj2
dj2's Avatar
Trader Rating: (28)
if you have some available
Old 11-15-2008, 12:18 PM   #5 (permalink)
fixed it. i pulled out injectors and i guess they were clogges so i just turned the motor over a few times with injectors out. popped em back in and it runs fine
Page generated in 0.13498 seconds with 13 queries
