Old 11-29-2004, 12:41 PM   #1 (permalink)
dodge2004srt4's Avatar
Member Number: 18024
Trader Rating: (37)
Default Help with code PO888 w/toys install
I got this code after finishing my install of my stage 2 with toys. It is a pending code and I have tried to erase it and it comes right back as soon as I start the vehicle. Initially I had 11 codes when I first started the car and it stalled but they all went away when I restarted it. I double checked all the wiring done before I hooked up the PCM connectors. No codes remain except this one.
PO888
TCM Power relay sense circuit
Any real ideas?
Thanx, Chris
11.59 @ 121.29 MPH 1.84 60ft
Stage 3 Methanized....coming soon
My mods require a DCR security clearance!
dodge2004srt4 is offline   Reply With Quote
Old 11-29-2004, 05:54 PM   #2 (permalink)
pdieppa's Avatar
Member Number: 12097
Are the toys working?
Percy
'04 Red SRT-4
Stage 2 w/o Toys
4headlights.com CLK Lights
$20.00 Catch Can
Prothane MM Insert (Lower Mount)
JLM Billet Mount
Denso Iridium Plugs
9MM Red Plug Wires
K&N Drop-in Filter
Sylvania SilverStar Headlights
Sylvania SilverStar Foglights
pdieppa is offline   Reply With Quote
Old 11-29-2004, 09:45 PM   #3 (permalink)
Trader Rating: (37)
The intercooler sprayer isnt hooked up yet and the LED for the octane switch isnt plugged in yet. The Dial a boost works fine and I didnt have one MIL come on in the 50 miles I drove to and from work today. Still have the TCM code though.
Chris.
Old 11-29-2004, 10:10 PM   #4 (permalink)
csx321's Avatar
Member Number: 4534
Trader Rating: (24)
Sounds like you're using a DRBIII? From what I've read, that code is normal for toys. It's because the toys PCM is from an auto transmission application.
http://srtforums.com/forums/showthre...ighlight=p0888
'04 SRT4, '87 Shelby CSX, '89 Shelby CSX, couple of others
2006 One Lap of America LER Media Crew
2009 Midwest SRT Nationals Attendee
csx321 is offline   Reply With Quote
Old 11-29-2004, 11:58 PM   #5 (permalink)
Trader Rating: (37)
Crap, you know I think your right. Ill look into one other possibility i found while digging through the FSM. Thanx!
Chris.
Edit: They should put this code in the diagrams as the code not to worry about cause I dont get the PO633 code on either stage 1 or stage 2.
Old 11-30-2004, 12:01 AM   #6 (permalink)
shmirgin44's Avatar
Member Number: 3292
no thats the skim key code 6033 you are thinking of....
CSC Member #3
SRToc Member #194
Stage 2 Owner #4=12.61@110 1.9 60' (spinnin' 2nd like a MOFO... )
shmirgin44 is offline   Reply With Quote
Old 11-30-2004, 12:06 AM   #7 (permalink)
Trader Rating: (37)
I dont get that code (read above).
He really is correct, my mistake. Forgot it was an ATX PCM I think from the PT Turbo Auto and thats another reason why they cant use toys asside from fitment of the toys bezel.
Anyway, Thanx guys!
Chris.
Old 11-30-2004, 04:52 AM   #8 (permalink)
glhs837's Avatar
Member Number: 215
Chris, a quick question,
I assume both of your kits are used and reflashed, correct?
Old 11-30-2004, 10:22 AM   #9 (permalink)
Trader Rating: (37)
I sent stage 2 to flight systems for VIN reflash, stage 1 still has my VIN in it from when the dealer put it in before I got the car. All done properly and everything is working good now. No change to boost levels as without the toys. If you run without the toys you get full boost in every gear like setting 3. Im going to update the other thread.
Old 11-30-2004, 10:28 AM   #10 (permalink)
glhs837's Avatar
Member Number: 215
Hmm, you did a Flight sytems flash on your S2, but it displays no P0633? AFAIK, that's immpossible. Has the S2 been redone with a DRBIII in the car at all? Or just left alone with a tech? I know of one case where the guy said he didn't have the code, but didn't know his buddy (the tech) had reflashed it for him.
Old 11-30-2004, 11:19 AM   #11 (permalink)
Trader Rating: (37)
Stage 2 was flashed by flight systems to get my VIN in but it has not been touched by a DRBIII ever, just a really good code scanner. I havent been to the dealer yet. As far as my stage 1 I dont think the dealer ever reflashed it since the car was brand new when they put stage 1 in it and probably never had a reason to. BTW what is AFAIK? Ive never figured it out.
Chris.
Old 11-30-2004, 11:35 AM   #12 (permalink)
glhs837's Avatar
Member Number: 215
As Far As I Know
Have you actually pulled the codes using the key?
Old 11-30-2004, 11:42 AM   #13 (permalink)
Trader Rating: (37)
As Far As I Know
Oh yeah, I forgot. (AFAIK)
Yes Ive pulled the codes with the key and with an Actron scanner. I dont get PO633 on either, ever, on any Staged upgrade. If I can find my camera I will take a pic of the DONE message and of my code scanner stating the PO888 code only. Maybe my car or set of PCM's are somewhat unique?
Old 12-01-2004, 02:21 AM   #14 (permalink)
shmirgin44's Avatar
Member Number: 3292
this is the ONLY time I've ever heard of this.....weird
Old 12-01-2004, 04:50 AM   #15 (permalink)
glhs837's Avatar
Member Number: 215
First time for me too. Should be impossible, since both the key itself and the SKIM module have to physically be present to send that SKIM key data to the PCM. But who knows.
Page generated in 0.23230 seconds with 13 queries
