HELP! Car won't start - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-16-2013, 01:17 AM   #1 (permalink)
midwesrt4's Avatar
Member Number: 79546
Default HELP! Car won't start
I have a 2004 str4 with 68k miles. I went outside to start her up and let her warm up before I went into work. When I turn the key, the car cranks but it doesn't want to fire up. The battery is fine, just replaced it about two months ago. Spark plugs were changed about 2k miles ago. The weird thing is I just drove it yesterday, and it ran fine and started up with no problem. I feel like it isn't getting any fuel but I could be wrong also. Anybody have any ideas? The car isn't throwing any CELs. I wish I had time to check if it was getting spark but I was the only one at my apartment and I had to be at work in 30 mins. Now im stuck in the hospital on my 12 hour shift and all I can think about is what could possibly be the problem. I do live in Omaha, NE and could the fuel filter possibly be clogged? I know almost 98% of the gas stations have a percentage of ethanol mixed in. Any ideas and tips to what to check and how to check would be appreciated. Thanks everyone.....
when the turbo spins, the bull$@!* ends ....
midwesrt4 is offline   Reply With Quote
Old 01-16-2013, 05:03 AM   #2 (permalink)
badboydneon's Avatar
Member Number: 63272
What's the temps like over there? Could be frozen lines due to moisture. Or could be a dead pump.
2004 Black SRT-4-
Mopar Stage 3 with the works
2003 Silver SRT-4-
BW s200sx-rs-56 .63ar
1997 Black 1G, 2.4 built and turboed-project
Any1 local in need of PCM flash...hit me up
badboydneon is online now   Reply With Quote
Old 01-16-2013, 05:05 AM   #3 (permalink)
midwesrt4's Avatar
temps are rising right now, but lately have been around 8-12 degrees
Old 01-16-2013, 05:06 AM   #4 (permalink)
midwesrt4's Avatar
And when I turn the key, I can hear the fuel pump prime
Old 01-16-2013, 07:23 AM   #5 (permalink)
midwesrt4's Avatar
battery is fine, checked spark, car has spark. any other ideas??? help please!!!!!!!!!!!!!!!
Old 01-16-2013, 07:34 AM   #6 (permalink)
midwesrt4's Avatar
anyone?????????
Old 01-16-2013, 07:48 AM   #7 (permalink)
*ALEX*'s Avatar
Member Number: 79647
Do you have fuel pressure? Have you checked the starter?
Quote: Originally Posted by lVlemphizStylez View Post
When I open my hood people think the car is on all kinds of steroids
*ALEX* is online now   Reply With Quote
Old 01-16-2013, 07:49 AM   #8 (permalink)
*ALEX*'s Avatar
Does it have gas?
Old 01-16-2013, 07:56 AM   #9 (permalink)
benspilk09's Avatar
Member Number: 88421
Does the fuel pump run when you turn the key on? If you have fuel pressure then check for spark.
benspilk09 is offline   Reply With Quote
Old 01-16-2013, 07:57 AM   #10 (permalink)
midwesrt4's Avatar
yup the starter is fine. the car turns over just doesn't want to actually fire up. I don't have a gauge to check fuel pressure....
Old 01-16-2013, 07:59 AM   #11 (permalink)
*ALEX*'s Avatar
I can almost assure you its not getting spark check your coil
Old 01-16-2013, 08:00 AM   #12 (permalink)
midwesrt4's Avatar
when I turn the key to the ON position, I can hear the fuel pump kick on..... and car does have spark, I checked that already....
Old 01-16-2013, 08:01 AM   #13 (permalink)
midwesrt4's Avatar
I pulled the boots off the plugs, stuck a screwdriver in each one and let it set close on the head, and I could see that spark coming off
Old 01-16-2013, 08:02 AM   #14 (permalink)
midwesrt4's Avatar
I did do a fuel pump rewire on my car awhile back, could the fuse be out and be causing this?
Old 01-16-2013, 08:37 AM   #15 (permalink)
*ALEX*'s Avatar
Check your relay and fuse ...but you said its priming ..I would jump the pump to see if its working
