HELP! Car won't start - Page 2 - Dodge SRT Forum
post #16 of 26 (permalink) Old 01-16-2013, 09:43 AM Thread Starter
midwesrt4's Avatar
Quoted: 7 Post(s)
ok. I just have to wait for the people behind to move their vehicles so I can get mine into a flat parking spot. right now it's on an incline. I'm thinking maybe the fuse from my rewire went bad. I mean it has been about 9 degrees out here for awhile, and during the day the roads are wet from melting snow, but at night it all freezes again. And these are the times that I have to go to work and what not.
when the turbo spins, the bull$@!* ends ....
midwesrt4 is offline
post #17 of 26 (permalink) Old 01-16-2013, 10:21 AM
Bossy's Avatar
Quoted: 0 Post(s)
My guess would be FPR/Filter. Maybe pull it out, let it warm up a bit, re-install, and try again?
2005 NSRT-4 SOLD...
3" Catless TBE, 3" O2 housing, AEM UEGO wideband, JMB hot/cold hardpipes, Greddy Type-S BOV, MPx 55mm Throttle Body, EBay BFMI, DCR big oil filter kit, DCR oil modifier, MSD 8.5mm wires, AEM SRI, Foward Motion WGA, 180* thermostat, Maddog STS, Stage 1 PCM, Stage 1 springs/stock struts, stock turbo on PCM boost
Bossy is offline
post #18 of 26 (permalink) Old 01-16-2013, 10:25 AM
Bossy's Avatar
Quoted: 0 Post(s)
Blown fuse= No power= No pump. You said you can here your pump prime.
2005 NSRT-4 SOLD...
Bossy is offline
post #19 of 26 (permalink) Old 01-16-2013, 10:33 AM
Quoted: 345 Post(s)
Until you check fuel pressure, you are wasting your time.
2005 SRT-4, BW Stage 3, Tuning...
2002 Camaro SS M6, Turbo kit in, working on things!
2003 SRT-4 Sold!
enginjoe is offline
post #20 of 26 (permalink) Old 01-16-2013, 10:37 AM
*ALEX*'s Avatar
Quoted: 0 Post(s)
This has to be the pressure
Originally Posted by lVlemphizStylez View Post
When I open my hood people think the car is on all kinds of steroids
*ALEX* is offline
post #21 of 26 (permalink) Old 01-16-2013, 10:39 AM
Quoted: 345 Post(s)
Oh yeah. Does it have enough fuel? Sometimes a weak pump will come back alive enough to start and run with more gas in the tank.
2003 SRT-4 Sold!
enginjoe is offline
post #22 of 26 (permalink) Old 01-16-2013, 03:06 PM
New Member
2004-srt4's Avatar
Quoted: 0 Post(s)
i had an issue like this like 2 months ago I stopped at advance auto parts and then when I came back think start. the battery was fine coils and wires where too. try to jump started and nothing. So i took the risk and bought another battery and it finnaly started. took the old battery to get checked if it was good or not and it was good the guy at the auto parts said that it may have been that the pcm needed a reset for some reason. finally put the old battery back in and started up fine. so disconnect the battery maybe it'll start.
PTE 5831 turbo kit,Needswing electric cutout,Agp hard pipes,Hks bov, Agp intake, Agp Motor Mounts, Agp tranny mount,BFMI, WOT box, DSP, AEM wideband
MORE TO COME
2004-srt4 is offline
post #23 of 26 (permalink) Old 01-16-2013, 07:06 PM
csteffl525's Avatar
Quoted: 0 Post(s)
im having almost the same problem, thing is mine will start sometimes... it turns over like a champ but it just doesnt fire sometimes
csteffl525 is offline
post #24 of 26 (permalink) Old 01-16-2013, 09:39 PM
Bossy's Avatar
Quoted: 0 Post(s)
Cam position sensor/magnet, fuel pressure regulator/filter, coil, plugs.....take your pick.
2005 NSRT-4 SOLD...
Bossy is offline
post #25 of 26 (permalink) Old 01-19-2013, 04:28 AM
4ast4orward's Avatar
Quoted: 0 Post(s)
I just dealt with a similar problem I could faintly hear my fuel pump turn on, but when i would check my fuel pressure ( At the end of youre fuel rail theres a small pressure fitting with youre key in the on position press the tab in with a small screw driver or w/e fuel should gush out) I wouldn't have any it turned out too be my fuel pump rewire relay but yeah Fuel/spark/compression is all it takes to run an engine also a good way to check you're spark is too remove you're spark plug attach it too a spark plug wire and crank you're engine if you see Sparks you're obviously getting spark I would recommend checking spark before checking fuel pressure lol.
4ast4orward is offline
post #26 of 26 (permalink) Old 01-20-2013, 04:31 AM Thread Starter
midwesrt4's Avatar
Quoted: 7 Post(s)
Thanks for all the help everyone. It turned out to be the power wire for my fuel pump rewire was seating right and wasn't making a good connection. It's all fixed now and running good! Thanks again everyone
User Tag List
Linear Mode Linear Mode
