Hi guys im having a hanging idle/ high/bad idle issue, when running the car at idle will be around 1200 rpms, but after awhile it go to around low 900s but will bounce around, sometimes while cruising it will seem like i dont have to press the gas pedal and it will continue going at whatever speed i took my foot off the pedal, and sometimes at idle will have a bad idle and die, the afr show it leans out and dies, i have changed out TPS, IAC,new stock throttlebody, looked for vaccum leaks sealed them, rewired both the iac and tps, have tried new injectors, new plugs , new wires, new coil, still having the issue any help??
