Old 05-10-2008, 12:16 AM   #106 (permalink)
04RedSrt-4's Avatar
Member Number: 56795
Trader Rating: (79)
Took my car to dealer, the mechanic forund a code for the front left anti lock brakes sensor replaced that and no more codes, so then they got done was about to leave the dealer and my ABS light with brake light came on and the car wanted to shut off what fuck man whats wrogn with my damm car, and i took it back and it threw nocode so the mechanic and the people said drive it around for like saturday and sunday to see if light came on, and or if it stayed on the whole time you know, and my lights flicker interior and exterior lights flicker when hitting a bump or something why?BAttery , alternator was good the mechanic said, and battery good, HELP HELP HELP HELP HELP HELP.
04RedSrt-4 is offline   Reply With Quote
Old 08-21-2008, 07:52 PM   #107 (permalink)
Member Number: 66614
suscribed
Fry_ is offline   Reply With Quote
Old 08-25-2008, 12:26 PM   #108 (permalink)
Member Number: 43440
Trader Rating: (27)
Did you ever find out what this was? I had/have the same problem. A few months ago, I had a low brake switch code. It only came on for a few days and then went away. I then had my engine built. I was driving and every time I hit a bump, my brake and abs and seatbelt lights would come on. My stereo and wideband cut off and the car acted like it was going to die. I found that my battery terminals were loose, so I tightened them up and that fixed that. But now my car is dead all the time. If I let it sit for a day w/o driving it, and go to start it the next day, it wont start. It's like something drains it, and unless it is driven everyday the battery dies. Battery is brand new btw.
Mods:
jlhill is offline   Reply With Quote
Old 02-04-2009, 07:27 PM   #109 (permalink)
Member Number: 66703
I'm totally missing something here, regarding the brake clip/wire/clutch pedal issue. But, I don't see the problem that some of you are claiming.
I know it's been posted a while ago, but I didn't get to see the video.
Can someone post a decent photo of the situation WITH the clutch pedal fully depressed?
Maybe the original owner saw this thread and fixed it? I don't see how else it would have been situated.
The white clip is pointed down, pretty much directly away from the nearest part of the clutch pedal/lever, but certainly nothing is smashed
T-Four is offline   Reply With Quote
Old 02-04-2009, 09:08 PM   #110 (permalink)
phubarr's Avatar
Member Number: 36947
Trader Rating: (56)
Take a good look at the picture in my post.
Found Potential Factory Wiring Problem!
You can see where the pedal meets the wiring by the vertical line worn into the wiring.
2005 Black Dodge SRT-4 ACR - SCT PRP (S2 base), ND Performance TCS, Mopar Stage 3 Coilovers, Falken RT-615's, AFE Stage 2 CAI, Ported 52mm TB, MaxxFab 3" DP (catless), Innovate LC-1 wideband, Aeroforce Scan Gauge, and a Hurst Shifter.
1989 Black Dodge Daytona Shelby Turbo II
1972 Plum Crazy/Black Plymouth Roadrunner
phubarr is offline   Reply With Quote
Old 02-05-2009, 07:01 PM   #111 (permalink)
Yeah, I saw the picture. That's weird, too weird, especially since my clutch pedal/brake wire positions are nothing like that. Yeah, they look the same, but my plastic clip is below the pedal. I also don't see how some of you are
saying that you move the clip or wire, and now it's "over the clutch pedal"???
Eeeouuw. I'd hate to accidentally snag the wire, at at the wrong time, and get rear ended by a semi.
There's no way, short of me physically standing on my clutch pedal, with my entire weight (about a 250lb frame), that would even leave a hint of the pedal touching the wires. So, I have to go along with the responder who said to the effect of "the factory either did it right on my car", or they fixed it by then. I do know , though that my '05 was built late '04.
I'll try and get a photo of mine, WITH the clutch to the floor (with hand pressure). I think you folks may be standing on your clutch. I get full disengagement just pressing it to the floor, while remaining in my seat.
Otherwise, I'd say that your clutches hydraulics need checking and/or shifter cables have stretched, explaining the improved shifting, when you move however/whatever you relocate, enabling you to push the clutch even further.
I truly appreciate this thread, and since my ownership of this car, few people have driven it any sort of significant distance, and plan to keep it that way.
In fact, should I ever sell the car locally, there'll be no 'test drives' (It does work that way. I sold a motorcycle that way - with "NO test rides" in the ad).
Old 02-05-2009, 07:05 PM   #112 (permalink)
che'ssrt-4's Avatar
Member Number: 62738
Trader Rating: (63)
thanks!!!!!!!!!
"I downshift next to hybrids so they can hear me killing the enviroment "
che'ssrt-4 is offline   Reply With Quote
Old 02-06-2009, 07:08 PM   #113 (permalink)
BOY! Was I ever wrong!
I took photos of my setup, with my hand pressure pushing the clutch down all the way. Still, as before, I contend I don't have the problem. I have a ways to go. As I have a good clutch and cables (replaced in early '08).
<br>
I'm not sure about the elec. tape. So, it was probably fixed at clutch job time.
Thanks
Old 02-06-2009, 07:13 PM   #114 (permalink)
MrBonkers's Avatar
Member Number: 59878
ShazboT! i shall check this once it stops raining! thanks btw
this infraction is like my flair.You know, the Nazis had pieces of flair that they made the Jews wear.
MrBonkers is online now   Reply With Quote
Old 04-13-2009, 06:29 PM   #115 (permalink)
Member Number: 72091
would this cause my brake light to come on and then go off when i release the clutch going into gear mainly just 1st gear?
JWalker884 is offline   Reply With Quote
Old 04-13-2009, 11:51 PM   #116 (permalink)
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
No, you're low on brake fluid. Top it off and your brake light will go away.
James NWSRT-4
READ AND LEARN:
Old 04-14-2009, 07:06 AM   #117 (permalink)
che'ssrt-4's Avatar
Trader Rating: (63)
this thread is so for the win!
Old 07-17-2009, 03:10 PM   #118 (permalink)
Legoman's Avatar
Member Number: 53967
Dammit have to check this soon!
Legoman is offline   Reply With Quote
« tps code | P0301 »
Page generated in 0.26951 seconds with 14 queries
