Old 04-29-2005, 10:00 PM   #46 (permalink)
DippinOnV8's's Avatar
Member Number: 2206
It's possesed. JUst try putting some brake fluid in....it worked for me.
Ho-chee the racin superstar.
DippinOnV8's is offline   Reply With Quote
Old 05-01-2005, 10:15 PM   #47 (permalink)
UH-60SRT's Avatar
Member Number: 9588
yah the car is cursed I've known that for a while now... I guess thats what you get when you got 666 in your VIN
'03 RED SRT-4
Quaife LSD
Spec Stage 3 six puck clutch
Fidenza Aluminum Flywheel
Stage 2 w/ Toys
Innovate Motorsports LM-1 AFR
Maxx Fab 3" Turbo back single exit exhaust
ATP up pipe w/ Turbo XS type H BOV
AEM CAI
MSD wires and coil pack
Apexi TT
Greddy Profec B Spec 2 EBC
Clear Corners
Clear 3rd brake light
Stage 3 Coilovers
Progress rear sway bar
DC Sports front strut tower bar
UH-60SRT is offline   Reply With Quote
Old 05-06-2005, 05:25 AM   #48 (permalink)
zzz04pt's Avatar
Member Number: 26505
My PT Turbo had the same problem. Brake fluid fixed it right up.
zzz04pt is offline   Reply With Quote
Old 05-07-2005, 03:16 PM   #49 (permalink)
Member Number: 18463
yes its brake fluid your low top it off and it should happen
JackelSRT is offline   Reply With Quote
Old 06-27-2005, 01:25 AM   #50 (permalink)
Member Number: 25876
I went to test drive one at the dealership today (an ACR actually) with 10 miles on it....got on it from 2-4000rpm and BEEP the e-brake light and buxxer go off, this happened 3 times on the same test drive. I now believe I know what the problem was (brake fluid low) but why on a car with only 10 miles on it? Could this be a sign of a future more serious problem with the brake system?
"Chillin with my friends I went down to the deli; spent my last dime to refill my FAT belly"
-Beastie Boys
future owner? is offline   Reply With Quote
Old 08-13-2005, 02:12 PM   #51 (permalink)
Member Number: 31213
yeah i tripped out when the light came on too xcept i thought it was a big brake problem cuz when i turned hard it would come on, but no need to worry i just needed some fluid
blackoutsrt is offline   Reply With Quote
Old 08-19-2005, 02:04 PM   #52 (permalink)
Member Number: 2704
Mine started doing it too - I figured it is low brake fluid as everyone said, but still taking it into the dealer since it is still under warranty!
Just curious: anyone know if there is a leak in the brake lines or does it just use up the fluid somehow?
connermt is offline   Reply With Quote
Old 08-19-2005, 02:14 PM   #53 (permalink)
SyberKhanX's Avatar
Member Number: 541
it's not possible for the brake fluid to get "used up" it doesn't work the same as motor oil.... Not sure how this happened, but it happened to me at about 10k.
I added brake fluid, and problem solved. No biggie. I'm at 33k now and nothing happened since then, everything in good order....
SyberKhanX is offline   Reply With Quote
Old 08-19-2005, 02:15 PM   #54 (permalink)
Mopar Event Specialist
Dale Seeley's Avatar
Member Number: 150
yep, it uses it up, turns it into 'brake dust' on your wheels. Complain to your dealer about that and he'll replace the burners.
Street Ricers Unite! We've been persecuted too long.
Dale Seeley is offline   Reply With Quote
Old 08-19-2005, 02:17 PM   #55 (permalink)
Member Number: 150
Did your brake pads get thinner? maybe the extra room in the caliper has something to do with it/
Old 08-19-2005, 02:27 PM   #56 (permalink)
SyberKhanX's Avatar
Member Number: 541
Well - I assummed that it was the extra room in the caliper, but I asked about this a long time ago - maybe 2 years now... And somebody else told me that it wasn't possible for brake fluid to get "used up". So honestly, I have no knowledgeable experiance ther than from talk to other forum members...
It's quite possible that I'm talking out of my ass, but it was my understanding that brake dust is from the pads - the brake fluid just functions to transfer pressure to the calipers, which will get closer to the disc as the pad is worn away. If this is wrong, I would love to hear from an experienced person how it does function.....
Old 08-19-2005, 02:32 PM   #57 (permalink)
Member Number: 150
brake dust is from pads. The fluid doesn't get used up. As the brake pads get thinner, the piston in the caliper moves out, increasing the volume inside the caliper, increasing the volume of the system, and it *looks* like you've lost fluid. Put new pads back in and it will be full again....
Old 08-19-2005, 04:06 PM   #58 (permalink)
Member Number: 2704
Thanks for the input all - how long do you think or have you experienced the pads to last? I am at about 34K now...
Just wondering if the dealer is goign to tell me to change them to get some $ out of me
Old 08-19-2005, 04:09 PM   #59 (permalink)
JCX
Member Number: 553
Pads last as long as they last. Depends on the circumstances really. The dealer changing the pads is the risk you take by going in for service on the brake light coming on. I chose to avoid this by spending $2.00 CDN on brake fluid.
Save a retarded thread, use the search button.
2004 Silver Srt-4 - stock except for the "wink mod".
JCX is offline   Reply With Quote
Old 12-05-2005, 06:36 PM   #60 (permalink)
Member Number: 21513
yeeeeeeeea finally,. i also thought it was my turbo timer. i took everything off the other day and rewired it and it was still doin it. this whole time it was jus brake fluid!
strictly boosting is offline   Reply With Quote
Page generated in 0.30991 seconds with 11 queries
