Lets start at the top. What i wanted to do was install my turbo toys on my stage 3. What i got was a car that barely starts and is throwing codes.
First thing that went wrong we didnt unplug the battery. Put all the pins in like the diagram said. Ran all of the wires too.
Once we went to start the car, it didnt want to start. Tried three times started on the third. Went to give it gas and it sounded like it wasnt getting fuel. Car was real sluggish and nearly stalled. Turned it off and checked all conections. Everything was connected. On my next attempt to start the car, there was a clicking noise coming for the left (passenger side) of the motor. Didnt start. Checked the codes and got: P0633, P0122, P0335, P0123.
Next, I uninstalled all of the wires that were ran from the turbo toys. Car did the same thing. I need to know what i need to do to get this fixed.
ok well i tried using my stock pcm, tip\map sensor, but it wouldnt even start. can some one tell me where the crankshaft sensor is? I ordered a new throttle position sensor and a crankshaft position sensor. Some one please help
P0123 - TPS Sensor #1 high
P0122 - TPS Sensor #1 low
P0335 - Crankshaft Position Sensor Circuit
P0633 - SKIM key not programmed into PCM (nothing serious)
P0633 is normal for all stage upgrades until you take it to ta dealer and have them program your SKIM into the PCM. Vehicle will operate just fine with that code.
The others sound like your TPS and Crankshaft position sensor (CPS) probably somehow got damaged from you not having disconnected the battery. Get new ones and replace them AFTER making sure the battery is disconnected. Of course, you could have shot your PCM all to hell. Double-check your wiring on the toys also.
That's right. I hit him so hard he fell off the internet.
Quote: Originally Posted by noTe
Yo man. I put some 36 inch wheels on mine a month ago for the new 50 cent video. It was fsckin' baller.
well we disconnected the toys so i dont think that is the problem. If the Stage 3 pcm was bad, I was thinking that if i put the stock pcm in it would start. It doesnt even start on the stock pcm. Do you know where the crankshaft position sensor is?
