crankshaft position sensor location - Dodge SRT Forum
post #1 of 57 (permalink) Old 08-11-2009, 08:43 PM Thread Starter
HIERGLYPHICS3030's Avatar
Quoted: 0 Post(s)
so i'm trying to change the crankshaft position sensor. no idea where its at. anybody got a pic? i think i have a general idea where its at. looks like its hiding right underneath the starter. how do i get to it if thats it?
05 Flame RED
MAYHEM MOTORSPORTS
HIERGLYPHICS3030 is offline
post #2 of 57 (permalink) Old 08-11-2009, 09:53 PM
Quoted: 0 Post(s)
I was having problems with mine and found out 2 wires got cut doing the motor swap but I did replace mine, Its right ontop of the starter under the intake manifold I wanna say it was 1 10mm bolt or a 8mm I cant remeber, There is also a side bracket for the transmission you will need to pull and theres some turbo piping you will need to move also to make it easier on you. And you should be good to go.
Jeff
srt4Jeff is offline
post #3 of 57 (permalink) Old 08-11-2009, 10:20 PM
UpShiftSRT4's Avatar
Quoted: 17 Post(s)
Did it a few weeks ago. Under the starter and held in by 1 8mm bolt. Tough to get to, but 1/4'' socket extension and drive makes it easy.
I was laying on the ground underneath the car to do this and didn't have to move piping or wires or anything around. Just remember to open the orange clip and slide the connector off first.
REDBULL '03 SRT-4
*World's 1st & only 9second stock-PCM 5speed
*World's quickest 5 speed neon/SRT-4
(street car, near full weight, not a drag car, not a trailer car) 9.74 @152MPH
Record broken:
https://youtu.be/BSdIg4qVAbU
New record:
https://youtu.be/cBX3MktND-0
All builds & tuning in house
-Flame Red Performance Edison, NJ
UpShiftSRT4 is offline
post #4 of 57 (permalink) Old 08-12-2009, 03:06 PM Thread Starter
Quoted: 0 Post(s)
hmmmmm, one person says on top and one says on bottom? didnt think i saw anything on top and didn't find it necessary to move any pressure pipes. only problem im having is reaching this thing and finding it.
05 Flame RED
MAYHEM MOTORSPORTS
post #5 of 57 (permalink) Old 08-12-2009, 03:18 PM
yellow_66's Avatar
Quoted: 1 Post(s)
Cam pos sensor is on top by valve cover right side
Crank pos sensor is on bottom
This too shall pass
yellow_66 is offline
post #6 of 57 (permalink) Old 08-12-2009, 03:23 PM
hercfe's Avatar
Quoted: 0 Post(s)
crank pos sensor can be done without removing anything, BUT, it is a pain in the ass to do that way. just remove the bracket, the lower hotside pipe, and the starter, and it will be a cinch to get at. it probably will take just as long to do it that way as it would to do it the way upshift recommends. BTW, it only took me about 40 minutes to do mine by removing the bracket, starter, and charge pipe. installing the new CPS, then reinstalling everything else as well.
hercfe is offline
post #7 of 57 (permalink) Old 08-12-2009, 03:30 PM
Quoted: 0 Post(s)
here you go
che'ssrt-4 is offline
post #8 of 57 (permalink) Old 09-03-2009, 08:12 PM Thread Starter
Quoted: 0 Post(s)
Finally changed it. Did it withou removing anything but it was tough. Probably shouldve just removed everything like everybody said
05 Flame RED
MAYHEM MOTORSPORTS
post #9 of 57 (permalink) Old 10-23-2009, 02:14 PM
Quoted: 0 Post(s)
im going to try this tonight
drewharvey101 is offline
post #10 of 57 (permalink) Old 10-23-2009, 09:39 PM Thread Starter
Quoted: 0 Post(s)
i would highly reccomend taking off the starter and brace. make things a lot easier.
05 Flame RED
MAYHEM MOTORSPORTS
post #11 of 57 (permalink) Old 12-11-2009, 01:19 PM
Zero46's Avatar
Quoted: 0 Post(s)
Bump, is there a SRT-4 Specific crank sensor or is it the same as the base neon?
Zero46 is offline
post #12 of 57 (permalink) Old 12-12-2009, 10:12 AM
Quoted: 0 Post(s)
^^^ i believe is different. since the base model neon uses the 420a engine
just buy the 2.4 one bro.
post #13 of 57 (permalink) Old 12-12-2009, 01:18 PM
Zero46's Avatar
Quoted: 0 Post(s)
I can't seem to find that one. You know where I can get one?
Zero46 is offline
post #14 of 57 (permalink) Old 12-12-2009, 05:09 PM
Quoted: 17 Post(s)
Autozone carries it. Duralast brand. But it didn't work too well for me. It has a rubberized coating on the magnet and that hinders the signal. Worth a try though.
It ran between $15-30.
REDBULL '03 SRT-4
Record broken:
New record:
post #15 of 57 (permalink) Old 12-12-2009, 05:19 PM
Quoted: 0 Post(s)
I have a used one i took out from a working engine, but if i were you i would buy an autozone one! that's what i did with my cam pos sensor!
User Tag List
Linear Mode Linear Mode
