#46 (permalink) |
Member Number: 90013
Wierd, alot of people have this issue. Mine did that a little after i bought it, Its not a "clunk" but its a constant clicking type noise if i turn the wheel back and forth. Sounds like a piece of plastic is rollin around in the wheel lol.
| Sponsored Links | |||
Advertisement | |||
#47 (permalink) |
![]() Join Date: Apr 2008
Member Number: 63330
Thank you for the replies!
It is not a rotating noise, and there is not much play when pushing and pulling the wheel. It bounces up and down when I go over certain kinds of bumps and rattles. Sometimes it is loud enough to hear, but but mostly, it feels loose. My steering wheel seems to be on tight (no wheel-to-shaft movement) and as far as I know, the column is original and has not been in a crash. I bought it in 2008 with 7900 miles and it now has just over 50k miles. This rattle is a recent development. The shaft is in a tube, so I am not able to see it move, and I can't see the upper bearing (??) because I did not remove the wheel and all the other stuff that is behind where it attaches to shaft. Does anyone have pics of the area where the shaft come out of the tube? I would prefer to fix it myself, but want to know exactly what it is in case I have someone else do it! Btw, ToyoTech8811...I think you work right down the street from me. I can't believe we haven't seen each other driving around!
#48 (permalink) |
![]() Join Date: Oct 2011
Member Number: 86725
Sounds like we all have different problems.
![]() All are common though, I've searched about this plenty of times.
2005 PVK w/ GWA
Forward Motion E1, LCR ported & polished manifold, Tial 38mm wastegate. Powered by: E-85 Tuned by Dave, aka Duster360 ![]() |
#49 (permalink) |
![]() All are common though, I've searched about this plenty of times. Haha...yes, maybe! I have done a ton of searching for this, and have found lot about the clicking, but nothing useful info for what I have. Does anyone have a picture of the upper support for the steering shaft? Is there some sort of bearing in there that can be adjusted, shimmed, or replaced?
#50 (permalink) |
From my research the clicking is due to the clock spring. Someone can correct me if I'm wrong, but that is what I remember reading.
2005 PVK w/ GWA
#52 (permalink) |
I've taken up slack in the u-joint per instructions from "Dr. Who".. Didn't fix the problem.
The clunk seems like it's coming from this spring that has a little washer around it, on the column. I've moved up the washer to put more tension on the spring (fixing the clunk), but it always ends up working it's way down the column and clunking again. It's hard to explain but if you've been in there and observed you'll know what spring and washer I'm talking about.
2005 PVK w/ GWA
#53 (permalink) |
There's a few different things that could cause it
first read the FSM if you've had the column out at all, there is a centering procedure that has to be done before you tighten anything or it will bind under certain conditions. second if you bought the column used, or it's been in accident, or someone didn't know how to take the steering wheel off and pulled on it or took a hammer to the center bolt then they damaged the column and it has to be replaced. All modern cars have collapsible steering columns for safety reasons in accidents, if you impact them at all you can start to collapse them and they have to be replaced, no way around it. I had to replace mine when I first got the car because the previous owner had hit the center bolt with a hammer to take the wheel off. I just read your thread from a year and a half ago...did you fix yours? I've taken up slack in the u-joint per instructions from "Dr. Who".. Didn't fix the problem.
The clunk seems like it's coming from this spring that has a little washer around it, on the column. I've moved up the washer to put more tension on the spring (fixing the clunk), but it always ends up working it's way down the column and clunking again. It's hard to explain but if you've been in there and observed you'll know what spring and washer I'm talking about. Is it behind the clockspring? Does that washer support the steering shaft in the metal tube? I have seen the Dr Who posts, but it does not look like it applies to this. mine is verticle movement that is near/at where the steering wheel is attached. I'm not sure how this would suddenly wear enough for verticle movement only. I can move the steering wheel up and down without the column moving, and there is no perceptible movement in the u-joint at the other end. Does anyone have a picture behind the clockspring? I have been searching, but not found it yet.
#55 (permalink) |
I can't seem to find out why the spring decompresses itself. It's almost like the retainer isn't holding it.
When I have a friend pull on the wheel towards the back of the car I can see the spring moving and popping. Like I said I've managed to push the retainer up farther and it goes away for a day, and then back to the same old shit. Any ideas?
2005 PVK w/ GWA
#57 (permalink) |
I'll take some and post them for you.
2005 PVK w/ GWA
#59 (permalink) |
![]() ![]() Join Date: Feb 2005
Member Number: 24241
Harold I'm having the same issue as you. When i grab the steering wheel there is no movement side to side but there is a bit of movement up and down. Mine has been like this for a few months and it seems like it getting worse
![]() 12.33@114.36 339whp 381ft-lb<Mustang dyno Externally gated Stg3 turbo+bolt ons |
#60 (permalink) |
Shit I totally forgot about this. I'll be working on my car tomorrow. I'll snap some pictures of said spring and retainer that cause the in-and-out clunk.
2005 PVK w/ GWA
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
