make sure your turbo timer is off and turn the key on and off three times.(while the car is off) just turn the key to on position dont actually start the car
2005 SRT-4 stock turbo and manifold stage 0 no spray. Basic Bolt-ons with driver mod
12.52@ 109mph slicks 1.7 60ft and 12.75@111 on gforce tires
You forgot a bitch in the 05's.. p1188 (tip sensor performance).
This means your tip sensor is not matching what the map sensor sees. IE the map is clamped at 14 psi, but the tip sensor is getting more voltage than it should with only 14 psi of boost.
TJ
OLD POST BUT ITS OKAY....I got a p1188 code my friends from AGP TURBO told me The only way to get rid of it is by upgradeing my Srt to a Stage 1 kit (I have a wonderfull 05 srt-4) Is that what you did to get rid of the P1188 code?
DO a search for Fade's 05 tip mod. Some people have also had success with clamping the tip sensor.
brought the car to dodge, they said that the removal of the cat (perrin TBE) caused the check engine light to go on. They said it had something to do with the 02 sensor etc. Then they said I had to pay 49.99 for a service charge because I removed the stock exhaust and because the code registered (P- something...43). He said by law he cant even work on the car because he could get a 10,000 dollar fine. I said well I guess you are getting that fine because you are charging me 50 bucks which means you had to have worked on the car. We argued for another 20 minutes or so. He wants me to put the stock exhaust back on then he will work on the car and then report to dodge I have the stock cat on (supposedly he is reporting I dont), he said an aftermarket cat will not be good enough. They finally waived the fee because I refused to pay it.
