Car won't stop accelerating!!! - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 08-28-2011, 04:38 AM   #1 (permalink)
Member Number: 84867
Default Car won't stop accelerating!!!
I was driving my car the other day and it was fine but than as i put it in neutral the rpms would stay at 2500-3500 rpm. Then when it was in gear it felt like it wouldn't stop accelerating. I checked the tps wiring by slightly wiggleing the wires and the idle would jump around. I replaced the harness and the car ran perfect for a couple days. Tonight i drove it and as i downshifted into 3rd and then let of the gas and wouldnt stop again i dropped it in neutral and went up to 6000 rpm so i shut the car off and checked everything it all seemed fine so after a while with it off it went back down to idleing at 2500-3000 rpm and drove home like that but as i drove home it went back to normal. I'm gonna do a boost leak test later today see if i find anything. Has anyone had this problem before???
03' Neon Srt-4 E85
Stage 1 Kit, K&N Drop in, Mpx Side Exhaust, Deatsch Werks 1000cc Injectors, Walbro 255 Fuel Pump, DSP, Koyo Radiator, ACT HDSS, BC coilovers, Needswings Hard pipe, HKS SSQ, N2MB WOT Box, Mpx BFMI, 6000k HID's, Yellow fogs, Drag Dr 31 Wheels
Jr_Castillo847 is offline   Reply With Quote
Old 08-28-2011, 05:28 AM   #2 (permalink)
SRT of the Month
ERABBIT23's Avatar
Member Number: 39786
Bad vacuum leak. Check for boost leaks we had this happen to us the other day blew a intake manifold gasket out on the shop car at the track had to drive it home 35 miles idleing at 4,000 RPM. Drives nice on the highway tho cruising at 2,500 RPM in 5th gear at 66 MPH like cruise control!
World's Fastest 5 Speed SRT-4 and Only One in the 9's 9.87@149
Proven Track Passes, Not Talked About Dreams Since 2008
http://www.youtube.com/user/ERABBIT23
ERABBIT23 is offline   Reply With Quote
Old 08-28-2011, 06:20 AM   #3 (permalink)
Rhunter's Avatar
Member Number: 36794
You probably need a new Air Idle Control Valve.
Nunca Levanta
A Lotta turbo! Small motor! And a Go Pedal!!
Lets re-grow the community! Subscribe to: www.elralforacingmedia.com
Old 08-28-2011, 06:32 AM   #4 (permalink)
MrSRT4309's Avatar
Member Number: 59194
unplug the battery and plug it back, that happened 2 me once i restarted it like that and went away
MrSRT4309 is offline   Reply With Quote
Old 08-28-2011, 04:39 PM   #5 (permalink)
fivetoez's Avatar
Member Number: 9691
IAC wires may be broken internally @ the connector..it's common.
_____5TOEZ______ 1967 Cadillac Calais 429 2dr.,.... 1967 Chevelle 4sp. Conv.... ,1978 Dodge 318 "Factory Custom"van.,..... 2004 Dodge Srt-4,Stage1.5(E-Blue) & a couple motorcycles.
Old 08-28-2011, 10:17 PM   #6 (permalink)
i checked the iac connector and its missing the red lock clip is there any way to check the iac?
03' Neon Srt-4 E85
Old 08-29-2011, 04:33 AM   #7 (permalink)
SRTotM Moderator
Bad98rt's Avatar
Member Number: 78946
im with erabbit check for vacuum leaks i ve seen this happen a few times
Huge thanks to Chris, Bill, And Bob @MAPerformane for 95% of all my parts
Huge Thanks to Kevin Warren For.. Many many things
MAP EF4 stock block, stock head
452whp on EMS at 26 psi
100&92 octane mix
Fully built long block and big numbers coming!
Bad98rt is offline   Reply With Quote
Old 08-29-2011, 08:52 AM   #8 (permalink)
prevrexowner's Avatar
Member Number: 68977
Hopefully, the OP will give us an update. I'm having the same problem.
http://www.srtforums.com/forums/f24/...85/index2.html Post#18 = truth for stock vs. all others.
http://www.gnttype.org/techarea/turbo/intercooler.html
Also, Duster360 knows his $hit!
prevrexowner is offline   Reply With Quote
