Old 11-03-2009, 11:32 PM   #1 (permalink)
Member Number: 58474
Angry Car starts and dies immediately
I am having a problem with my car. If i disconnect the battery and connect it again the car will start and run for about 5 seconds and dies. Then it will not restart. This problem happened after I drove home the other day and I noticed the gauges would not work also The car was running for a few extra seconds after I turned the key off with the turbo timer turned off. I am pulling my hair out on this. Please someone help. Whoever gives me advice that can make my car work again I will give a reward.
twism10 is offline   Reply With Quote
Old 11-03-2009, 11:47 PM   #2 (permalink)
BLKDOUTSRT4's Avatar
Member Number: 36285
maybe ur key lost its learn for the skim.....cause thats what cars do when the key isnt programmed....do you have a spare key?
Quote: Originally Posted by Alpha-Omega View Post
....yeah, I'm gay and staying home this time
BLKDOUTSRT4 is online now   Reply With Quote
Old 11-03-2009, 11:51 PM   #3 (permalink)
Yes I have a spare key. How do I fix it
Old 11-04-2009, 12:10 AM   #4 (permalink)
try to start it with the spare key see if it still does it.....could have lost both skim keys but ive seen just a single key go bad before
Old 11-04-2009, 12:24 AM   #5 (permalink)
tried spare key still nothing
Old 11-04-2009, 12:27 AM   #6 (permalink)
I noticed when I try and start my car it cranks but wont start and the headlights go off when I try and start it. Very frustrating problem anyone got any suggestions.
Old 11-04-2009, 10:54 AM   #7 (permalink)
bump!
Old 11-06-2009, 11:01 PM   #8 (permalink)
srt-sparkle's Avatar
Member Number: 8546
My boy had an issue with his it was his computer which he changed. Then he changed his fuel injectors, fuelpump, and it solved the problem. You got alot of factors there. I would check the computer which has a skim like he said as a theft deterrent.
Its basically a chip in the key that sends a signal to disarm the immobilizer if the key is messed up or isnt recognized by the immobilizer the car will start up for a brief second or 2 and shut itself off.
No matter what you do "vengence is mine sayeth the lord" Im still the best,what good is power if your car can barely get traction. Selling mopar toys bezel along with harness PM Me i got pics.
srt-sparkle is offline   Reply With Quote
Old 11-06-2009, 11:11 PM   #9 (permalink)
19 psi's Avatar
Member Number: 12457
Trader Rating: (39)
skim key or auto shut off relay?
19 psi is offline   Reply With Quote
Old 11-07-2009, 07:06 PM   #10 (permalink)
Member Number: 59653
ASD chould do it too. Bad Auto Shut down relay can be bad. Go to junk yard or buy one at the auto store nothing $$$ bad i had to get one for mine cost me like 15$ at autozone idk if thats the same price for you but it worked fine.
2.4 Motor in 1995 dodge neon.
dtecneon is offline   Reply With Quote
Old 11-07-2009, 07:14 PM   #11 (permalink)
Member Number: 29081
Check the voltage on your alternator. It could be that, what yr and whats the mileage on the car?
1SlowNeon is offline   Reply With Quote
Page generated in 0.14225 seconds with 13 queries
