Anyone have any idea why my car won't start given this scenario??:
I Took a 2 day, 1200 mile trip to ohio from Florida, car ran fine the whole trip. I've had a P0420 code since i took out my cat (code has been on for about 4 months). Only mods are an AGP wastegate, walhboro 255, and boosting to 17.5/15.5. yes, i use a turbo timer everytime, set for 3 min's. After i parked it for the night in ohio, it snowed. Ever since then, when i turn the key to start the car, one of 3 scenarios will happen and it doesn't start. (Understand that all accesories in the car work: power windows, radio,lights,etc. . Also, when opening the door, the tripometer displays fine):
1. when turning the key, the dash will light up normally, the fuel pump will cycle, and then when i turn the key, nothing happens. no bad starter click, nothing.
2. when turning the key, the dash will be dark- no lights on at all- even the tripometer is blank. and when i turn the key, it may or may not make an electrical click sound.
3. when i turn the key, the display flashes 'done' as if i've just finished pulling it's codes.
Sometimes, it will start, but very rarely. over 7 days and literally 200 turns of the key, it's started up maybe 5 times. when i pushed it into a heated garage, after 2 days at 60, it started normally.
My gas tank has been more than 3/4 full (so no water/gas line issues)
I replaced the battery last week thinking it was a low battery (675 CCA)-- . no difference in the problem..
I have used a third, much more powerful battery, with no difference (thinking the new battery might be bad).
I've removed the battery cable for over 12 hours, hoping it's an errant electrical thing, but no difference.
Any ideas what this is?
Any ideas on how to get my car running so i can get back to FLORIDA???
Thanks in advance!!!
