Old 06-24-2008, 04:34 PM   #1 (permalink)
Member Number: 64572
Default car cams with stock cams help.
hey guys im kinda new here i have an 05 srt4 41,000 mile new plugs wires n coil pack msd plugs r gapped to .36 wen i start the car n it warms up a little it starts to idle like it has crane 14 cams in it. my friend has those cams in hos car and he was like you got the same cams as me n im like no there stock. can figure out what it is please help!!.....
killa 05 srt4 is offline   Reply With Quote
Old 06-24-2008, 04:35 PM   #2 (permalink)
Buy/Sell Moderator
uncommon©'s Avatar
Member Number: 39843
Trader Rating: (131)
vac leak ... check the bolts at the intake mani, the hose behind that intake mani that runs to the brake booster (which is behing the battery) and the small line that hooks up to the same piece on the brake booster ... it's common for those 2 hoses to come loose which will not only cause a vac leak, but will leave you with no brakes if the hose(s) were to pop off
if all of the above checks out, then get a spray bottle filled with water & start spraying around the intake mani, throttle body, etc. while the car is running ... if the car starts to bog then you have found your leak
11.9 @ 126
Page generated in 0.12622 seconds with 11 queries
