Old 10-27-2009, 11:35 AM   #1 (permalink)
dkjdsn's Avatar
Member Number: 27721
Default Cam Sensor and crank sensor Problem...
My car car died on me few days ago.........engine code was for cam sensor and crank sensor. So I change both sensors.....still car would not start....and still had the code come up!!!
Just checked my timing belt.........the problem was the timing belt!!!: Forgot that sensors codes pop up when timing belt is bad...... wasted money on the sensors!! Oh well......it was time to change them anyways.......
Changing the timing belt is gonna be a %^&#!
Word of advise......when you get the engine code for the cam and crank sensors......check your timing belt first before you go buy the sensors!!!
"but sanctify Christ as Lord in your hearts, always being ready to make a defense to everyone who asks you to give an account for the hope that is in you, yet with gentleness and reverence" 1 Peter 3:15
"Believers To Think And Thinkers To Believe"
"Truth Will Set You Free"
Mods: Needswing Cutout v.5, Rice Plate,TEIN s tech, Viper 791XV/ Remote Start/Turbo Timer Alarm......
dkjdsn is offline   Reply With Quote
Old 10-29-2009, 05:54 PM   #2 (permalink)
Probaholic1's Avatar
Member Number: 69183
what waz wrong with your belt i got the same codes
o
Probaholic1 is offline   Reply With Quote
Old 10-29-2009, 07:44 PM   #3 (permalink)
Member Number: 72904
x2^ and how did you check the timing belt?
drewharvey101 is offline   Reply With Quote
Old 10-29-2009, 07:46 PM   #4 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
that isn't really true... i had that problem and changed the cam sensor, reset the battery and no problems since
Pittsburgh Penguins 16-8-0 32 points
Old 10-29-2009, 07:54 PM   #5 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (57)
It's pretty easy to check the timing belt...you can always pop off the t-belt cover...3, 8mm screws and there ya go.
Old 10-29-2009, 10:21 PM   #6 (permalink)
is the t belt cover behind the top motor mount and if it is do i have to take it off to look at it?
Old 10-29-2009, 10:23 PM   #7 (permalink)
hercfe's Avatar
Member Number: 19255
no. it comes off in like 26 seconds. when you get it off, leave the bottom screw out, so you don't have to dig at it next time. FYI
hercfe is offline   Reply With Quote
Old 10-30-2009, 02:46 PM   #8 (permalink)
ok so i only found 2 bolts that hold the damn cover on i thought i found the third one but when i went to take it off i broke the cover...so where exactly is all the bolts that hold it in...not like it matters now that it is broke hope a new one doesnt cost that much
Page generated in 0.13280 seconds with 13 queries
