Old 11-13-2009, 06:39 PM   #1 (permalink)
mattewhite04's Avatar
Member Number: 76009
Default Cam. Pos. Sensor
So car threw cam position sensor..but car idles at 800rpm and drives fine, no 2100 rpm limiter its just at idle the car is lopy with a 12-14 on the vac gauge not 18. SHould I change the sensor, the caer only runs bad at idle...help. all my ignition(plugs,wires and coil are good also.
Injen Intake, DogBone motor&tranny mounts, lowering springs, AGP WGA, Coil heat shield,MSD wires, Agp hard pipes, greddy bov, running on wg controlled boost.
mattewhite04 is offline   Reply With Quote
Old 11-18-2009, 07:21 PM   #2 (permalink)
DiGiTaLReApEr's Avatar
Member Number: 8892
I'd change it, they are cheap. If you threw the code chances are it's shot. When it gets really bad the car won't start or will take forever to crank over and then run like crap.
2004 Flame Red SRT-4
DiGiTaLReApEr is offline   Reply With Quote
